Question about Philips DVP320 DVD Player
Philips dvp 3020 dvd player will not play, the "no disc" sighn keeps coming on.
I have just bought a philips dvp 3020 dvd player and it will not play any of my dvd's. it takes ages to to try to load and then shows the "no disc" sighn. i don't know what i'm doing, so have done very little. i have disconnected and reconnected the power, tried several discs, made sure the scarts are connected propely, and still no joy. can anybody help? thanks, lorna austen.
  • mandar v Sep 01, 2008
    I have DVP 3020 which only plays audio CD's , it does'nt play MP3 CDs & Video DVD CD's in Video CD's only sound comes no picture is seen. Pls advise what could be the problem and how do i repair it? Thanks
  • junior198 Oct 26, 2008
    I have the same problem :( it was fine, only just started doing it. someimes it says load for ages. then just says no disk. I have tried all kinds of disks from old to new, store disks, own recorded, music.. everything - does the same thing :(
Try this. Wait for the "no disc" sign to appear, and only after that load the dvd. The 3020 I have works alright when I use this method.
Posted on Aug 20, 2008
I bought some DVDs at, but I live outside the region code area witch the DVDs are supposed to work. I live in code area 4. I need someone to find a code to region 1. I have a Phillips home...
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Jan 28, 2011 | Philips Televison & Video
Philips DVP Playing problem
try to clean or change the laser
Mar 11, 2010 | Philips DVP642 DVD Player
Unknown disk error on philips dvp 3020
I would guess that it's an incompatible disk format. If your burning software allows you to pick different types check the Philips manual for a compatible format
Mar 06, 2010 | Philips DVP3020 DVD Player
Philips DVP 3020 says 'no disc' when you try to load any disk including a cleaner
I guess the problem was in internal., you try to open case and while operated with disc watch if the optical lens working, may also try to open region code to "0" or multi region
posible problem "NO DISC"
a. Optical Lens
b. FCC wire
c. Mpeg Board
d. Wrong Region
Clyde Acenas
Nov 04, 2008 | Philips Televison & Video
Region codes
Press "Setup"
Scroll to "Preference" using the LEFT/RIGHT arrow key
Press "138931" and a pop-up screen will appear.
Use the UP/DOWN arrow key to choose the desired number ("0" for any region)
Aug 26, 2008 | Philips DVP5140 DVD Player
My philips dvp 3020 dvd players is not playing any disks
There are only a few problems that cause this
1 laser is bad to costly to fix
2 sometimes just a cleaning video cleaner radio shack has
just clean laser a small clear looking eye
3 the servo boards go bad to costly
you could try buying a disc cleaner sometimes it fies problem
my guess would be the laser is bad i have looked at hundreds of these and 80 percent of the time it is a warn laser.
thanks doctor video leadingedge electronics since 1987
Apr 28, 2008 | Televison & Video
Wrong Region message
DVD player must be made region free by unlocking it.. after that you can play all the discs you want.. for ubnlocking it you can try google//
Jan 19, 2008 | Philips DVP-3005 DVD Player
Philips dvp 3020
This is usually caused by a faulty laser.
Most DVDs have two lasers. One for DVD & one for CD.
Sounds like the CD laser has failed.
Jan 19, 2008 | Philips DVP3020 DVD Player
Region codes
Philips DVP 3015K / DVP 3020 / DVP 3040 / DVP 3040K / DVP 5140 / DVP 5960
  1. Method 1:
  2. Open the disc tray
  3. Press SETUP
  4. Navigate to the preferences page
  5. Enter 138931
  6. Select the region using UP/DOWN
  7. Press PLAY
  1. Method 2:
  2. Open tray
  3. Press 9, 9, 9, 9, 0
Dec 19, 2007 | Televison & Video
Disc error
after recording, did you ensure the "finalize" or "lead-out" process completed?
May 25, 2007 | Philips DVP642 DVD Player
Philips DVP320 DVD Player Logo
816 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
