Question about Kenmore 24932 Top Load Washer
Will not run continuously!
My washer will fill with water, stop, drain some, stop, drain more, stop.... it is not running in a continous matter. For one load it is now taking it 7 hours and is still on rinsing cycle. What is the problem?
    Sergeant:
    Champion:
  • 223 Answers
Either you have a faulty module or timer switch the dial used to set the wash program. If for any reason it ha been turned in the wrong direction your machie can behave exactly as you describe. Hope this helps.
Posted on Jan 20, 2009
Water is draining continously from tank
its over filling its the soilnoid valve letting by u will need to replace it
Aug 26, 2012 | Electrolux Washing Machines
My estate washer continually runs water in the basin but won't fill up. It drains immediately out as the water runs in. What could be the problem?
Assuming the motor isn't running during fill the water is siphoning out and can be caused by a few things.
· The drainpipe to your house may be too low and you either need to extend the pipe up above the top of the tub or run the drain hose from your washer up high.
· Someone may have taped the drain hose from the washer to the drainpipe to your house to stop the water from backing up. To fix this either clean out the drainpipe to your house and remove the tape or install a siphon break.
· If the drain hose from your washer is pushed down the drainpipe too far, this will also cause the same problem. To fix it just pull it out to within about 6 inches of the end of the drainpipe.
Feb 08, 2011 | Whirlpool Washing Machines
Won't stop filling. Just runs & drains without
Check for a faulty water level switch. It's a diaphragm-like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the tube and when it reaches a certain level, it activates the switch to shut off the water and signals the timer to start the appropriate cycle. Check for any obstructions in or damage to the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad switch. Sorry for your trouble and I hope this helped. Best wishes.
Sep 17, 2009 | Kenmore 24032\24036 Top Load Washer
My washer keeps filling no matter the size I have
This sounds like a faulty water level switch. It's a diaphragm-like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level it activates the switch to shut off the water and signals the timer to start appropriate cycle. Make sure there is no damage to or obstructions in the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty switch. Sorry for your trouble and I hope this helped. Best wishes.
Sep 04, 2009 | GE WSXH208A Front Load Washer
WILL NOT STOP FILLING
Hello Friend, You either have a bad water level/pressure switch or your water inlet valve is bad. If you unplug the washer from the wall and the water stops filling the washer then it's not the water inlet valve. If it only continues to fill when wash cycle is started then you will need to replace the water level/pressure switch behind control panel. This should solve your problem. Happy to help, Tim.
Jun 30, 2009 | GE WHRE5260E Top Load Washer
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
Drain pump runs continuously. Nothing else happens!
Water had accumulated in the sump - a plastic tray at the bottom of the dishwasher which catches any leaked water. This operates a float switch which makes the drain pump run all the time. The fix was to tilt the dishwasher backwards to drain away the water. It isn't filling up again, so I'm not sure where the water came from, but I'll keep an eye on it!
May 17, 2009 | Bosch Dishwashers
Hotpoint washer fills begins to agitate then refills continously.
Very likely your drain hose is set too low. You can solve this with a standpipe or a kit called a siphon break.
Dec 31, 2008 | Hotpoint VBSR3100GWW Top Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 24932 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
