Question about Mitsubishi WS-55807 TV
1993 Mitsubishi 35" Tube - no color on any input > only on menu
Our 1993 35" Mits tube worked very well for several years then was stored for about 5 years; after storage the picture was very good and it worked for several more years. Eventually it developed a daughter board - circuit board solder connection failure on surface mounted caps. The tech that came out was moonlighting (oh how I wish I could find another moonlighter now) and told us the colors were starting to run a little but for the age it was a nice picture. To us, since we use this in the den about 6 hours a week, the picture was still great.
About a year later or 5 years ago (yes we've been watching things in black / white for several years - it helps keep the wife & kids busy elsewhere) we lost the color on the set on all inputs including Coax, S-Video and RCA. The colors show up when in the menu mode and seem to be there in terms of capablity because when the tint / colors are adjusted you can see red/green/blue outlines or color noise in the background of the images.
We're looking for a tech who can fix this set and another one (afterhours for cash - in the Lansing, Michigan area) or someone nice enough to help locate the area of the TV I can look for circuit board solder issues and/or failed components. I have a few years electronic / TV repair experience from my college era, granted it was several years ago, I'm still good with a solder iron and fluke meter. Please help me determine know where to look and what to look for! Would this be failed cap(s) or an IC chip issue or diodes or solder connections? Does the set need any mods?
And I want to thank you for your contribution to corporate decline, over inflated everything. Welcome to the era of DIY - not because we want to, because we have to in order to survive!
  • 927 Answers
Good Day, lhcsmi; That year model of your TV it will be the PIP MODULE; PULL PIP PCB FROM SET, JUMP OUT 'VP' CONNECTOR WITH 1UF CAP FROM PIN 7 TO PIN 9 AND 1UF CAP FROM PIN 11 TO PIN 5.CHECK ALL ELECTROLYTIC CAPS AND TRACES CONNECTING TO THESE CAPS FOR CONTINUITY. The board is about 3x5, it's in the towards the back of TV's chassis in the middle of chassis. The caps are best to install on the bottom of the main "mother board", the board is numbered. Do not re-install board. You will correct problem but will loose the PIP function. I can't help with side tech from here in TX, but there is many good tech's in the Capitol, of MI, moved 25 yrs ago from that area. I hope this was helpful. Good Luck, big IRISH.
Posted on Jul 29, 2008
  • Mitsubishi Master
  • 19,396 Answers
Here is a list of qualified tv repair in your area:
Lansing Televisions Service & Repair in Lansing MI
Mits. rear projection tv ws65905 picture has blue color tint
Your blue picture tube is failing. Invest in a new TV. "If" you can find a new set of tubes(you have to replace all 3 red blue and green) they are around $800-1000. Not cost effective. Run the TV into the ground if you want to wait but do not invest any repair money in my opinion.
Jun 01, 2015 | Mitsubishi WS-65905 65" Rear Projection...
WHY DOES IT KEEP TURNING OFF
Yes. Rear-proj.with 3 picture tubes. These, like most newer tvs have self-checks that shut the tv off if the fault could worsen problems for the TV (such as damage picture tubes.) or it's not able to put a picture up.
After it shuts off, you can press menu and input/device together for 5 secs, and it will flash a 2-digit code (such as "23" or "24", etc.)(vertical or horizontal error.) Though you will need to call a repair shop for repair. It's usually better if they are Mits. factory authorized, as they'll likely have more exper. on Mits.
Apr 24, 2014 | Mitsubishi WS-65511 65" Rear Projection...
I have a Mits WS-65511 that the picture lighting started to to fade in and out. We still have sound but the picture is not the right color, fussy and lighting is dim. I did reset the TV, no difference. I...
Three basic color picture tubes in tv are getting weak in performance and requires more current to work properly. There is Screen voltage settings that needs adjustment for each picture tube in tv.
Let me know are you familiar with electronics stuff repair and willing to work in live tv?
Thanks.
Jul 03, 2011 | Mitsubishi WS-55513 55" Rear Projection...
My hubby lost the oil dipstick, I have a new one, WHERE DOES IT GO? I CANT FIND WHERE THE DIPSTICK GOES in my 1993 Mits Mirage!
Thats easy... just look for a tube opening in the front of the engine. The hole will be roughly a 1/4 inch big.
Jan 06, 2011 | 1993 Mitsubishi Mirage
I have a sony wega and the picyure is clear but has a green tint what could that be
There are several possibilities in that area. The Picture Tube (CRT) is driven by three different video signals. One presents the Red, one the Blue and one Green. All other colors are derived from a mixture of those three colors. The greenish tint could be a sign that the green gun is being over driven or the Red and the Blue are less than adequate to create a normal picture. Sorry to say this but the most common problem that causes that symptom is the emission in the "gun" assembly inside the picture tube is declining with age and hours of operation. Sony Picture tubes are typically good for around 40,000 hours of use. I don't recommend replacing the picture tube. If the set is more than 5 years old I would suggest that you start looking for a new set.
I know this is bad news but I am just telling what I know the most likely scenario that I have seen in 35 years of TV service.
Zashiban
May 29, 2010 | Sony Televison & Video
Flatline!
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
May 15, 2009 | Mitsubishi CK-35308 35" TV
Mitsubishi Diamond Series T.V.
When a tv (Rear proyection) shows this coloration is the meanning that the red color is not there (the red color is generated by a red CRT). Now it can be really bad not having the tube working but before conclution make sure of this: (and if the red color gets back then the tube is ok)
  • is this condition the same in all inputs? or the picture looks ok with a different video source (VCR, DVD other)
  • are the menu letters same as the picture looks or are they fine?
If we cannot see any red color back with this testing, still chances that a technician find an electronic problem that make the tube to be off. so don't rush conclusions and get to the end to save the tv with out replacing the red tube, but if all was done and nothing then the tv needs the tube replacing.
Mar 03, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
Unlock Menu
I need a password to unlock my Mitsubishi TV Model # CS40707 Serial # 503994
Jan 02, 2008 | Mitsubishi CS-35707 35" TV
Red / Green issue when connecting Mits DVD to Mitsubishi TV
Convergence problems, look in menu and find manual conver. and read for more info goto ctechnicians.com
Dec 22, 2007 | Mitsubishi WS-55511 55" Rear Projection...
No red, orange, pink or green color!
Sounds like your green tube is low or is bad
Mitsubishi > VS XXXX
this model is famous for fluid leaks. each projector True True (``````````` (``````````` 0 95250 95250 clip_image002.png tube has a reservoir on the front of it with a fluid in it. this keeps the face of the tube cool.
this depends on how bad the damage is in the tv. in most cases we can reseal the tube and clean up the fluid 400-600.
Once you
take the tube out you will see where it leaked. The problem is that the
frame on the CRT that the heavy screws with springs are mounted on (that
hold the lens coupled to the CRT) is weak and they can bend. We have seen
several that have leaked after the customer moved the set. You can only
tighten them down so much because the frame bends. It is just stamped metal
and not welded at the corners to support the bend.
We remove the CRT, clean it all up, add a very small amount of RTV sealer to
the gasket, reassemble, let the RTV cure thoroughly and refill with coolant.
The extra sealer should prevent future leaks. Haven't had a recall yet.
Mits says replace the CRT...too costly.
You msut check the yokes carefully as well. If any coolant gets into them
you can end up with shorts there and a mess.
Clean the boards carefully and repair any corrosion damage. The coolant is
ethylene glycol and glycerine which is water soluable.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi WS-55807 TV Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
