Question about Sewing Machines
Machine died I was sewing along and suddenly the machine went completely dark. After letting it sit idle for a bit, I turned the switch back on and it would not respond. It has been dead ever since. Could this be a fuse problem? I just tried to turn on my sewing machine and it is totally dead. I have a Janome 6500. I have unplugged it, tried a working outlet, etc. but no luck.
Possibly like my Bernina. Needs new on/off switch.
Posted on Sep 01, 2008
Hi, Janome 124 - top thread picks up the bobbin thread, motor sounds good. Th feed dogs won't pull fabric (or paper) thru the machine - dogs don't stick up much above the plate. Help please! Jan
Remove the needle plate and clean the feed dogs with a brush...remove any lint and bits of thread.
A couple of drops of sewing machine oil might help to loosen the feed dogs up. (maybe let the oil seep in and then turn the handwheel towards yourself to help things along.
One other thought:
If your machine has feed dog lowering capability you might want to move that lever/switch back and forth a couple of times.
The feed dogs might not appear to raise or lower, but some machines will only re-engage raised feed dogs when the machine starts to stitch.
Also...verify that the presser foot tension isn't too strong/heavy...and temporarily try using a longer stitch length setting.
Mar 19, 2017 | Janome Sewing Machines
Problem with feed dogs and thread catching
Hello Emma,
Hope this helps.
When the feed dogs are lowered they will not go up with just the switch. Try this, move the feed dog switch to the up position, then turn the handwheel 1 complete rotation. Voila they should be up. Let me know if it is solved. Chris
May 30, 2017 | Janome Sewist 525S Mechanical Sewing...
Hello, I have a Brother NX200-Innovis computerized sewing machine. It was sewing like a dream when all of a sudden it slowed down and beeped and flashed "E6" . The balance wheel has completely...
turn the sewing machine completely off
rethread the machine the top thread & bobbin, if possible use a different spool of thread for top & bobbin
then turn the sewing machine on again & see if you still get the same message, if the same message still displays,,then it needs to be serviced
Aug 10, 2011 | Brother NX-400
How do i unstick my sewing machine
I'm not sure what you mean by 'unstick'? What is the machine doing (or not doing)?
I've found nothing beats a good cleaning and oiling to keep a machine zipping along. I have had machines sew nicely for hours, then suddenly come to a screeching halt. Cause: a tiny bit of thread or lint that got caught up in the bobbin mechanism. If this is the problem, it helps to use a bright flashlight to look around for the offending thread or lint.
Hope this helps!
Jan 19, 2010 | Brother LS-2125 Mechanical Sewing Machine
I was sewing along fine and then all of a sudden my thread started "birdnesting" I have rethreaded the machine as well as the bobbin. It works great on a practice run but as soon as I go back to my project...
Yes, VERY frustrating! When this has happened to me it has always turned out to be a tiny bit of thread caught in the bobbin assembly. I've rethreaded and rethreaded but could only solve the problem by taking the bobbin assembly apart and finding and removing the caught thread. I use a bright flashlight to help find the caught threads.
Good luck and I sure hope this helps!
Robbie
Jan 14, 2010 | Singer 5050 Mechanical Sewing Machine
No driver support for 64 bit computer. My computer went out and my new one is a 64 bit machine.
most items produced before windows 7s came along will not operate on that particular operating system
Nov 23, 2009 | Singer CE-100 Futura Computerized Sewing...
Similar issue with bunching on the bottom side of vinyl
when sewing thick fabrics and when using thick threads you will usually need to tighten top tension - on most machines to maximum in order for the machine to pull the thread up into the fabric. you must also use a needle which will slide along the thread when thread is through eye of needle (take needle out of machine, put thread through eye and see if needle will pass freely along thread - if not, use a larger needle)
scott.
Jul 11, 2009 | Bernina Activa 130
Brother sewing machine will not make continuous stitches
first you should turn off the machine and let in reset it's internal programs. Yes the feed dogs are very important. start your machine again...set the feed dogs...unthread and rethread teh machine from start to finish to include taking out the bobbin and replacing it. then make sure you bobbin winding in completely in Un using mode...
May 22, 2009 | Brother Sewing Machines
Machine died
More than likely this is a fuse problem. This should go to a Janome Dealer or someone who is familiar with Janome/New Home Machines. The fuse is located in a box underneath the bottom of the machine.
sewman7
Jul 29, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
