Question about Apple M6496 17" CRT Monitor
COMPATABLE WITH IBM
IS THE 6496 COMPATABLE WITH A IBM TYPE COMPUTER. IF NOT CAN THE CABLE BE MODIFIED TO MAKE IT WORK. WHERE CAN YOU GET A SCHEMATIC TO MODIFY IT IF POSSIBLE.
Owner manual for Sears stove model c880 6496 182
you must have the serial number there Sears has not record of that model number.
Jun 15, 2014 | Stoves Ovens
What type of video card is compatable
The X335 has an ATI RageXL video controller integrated on system board, but if that is not working then it has two PCI-X slots which would accept any PCI adapter. Check usage here: http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-45476
Apr 25, 2014 | IBM X335 (8676y13) Server
I have upgraded lenovo x230 tablet from win 7 to win 8 and the double tapping on the touch screen is not working, when i get into calibration mode the mouse pointer dissapeers can someone help
A common problem with OS upgrades is often the driver for devices aren't correct or compatible. Look for a device in Device Manager that is in error or a Unknown Device. You can sometimes tweak the Win 7 drivers to function with Win 8 by modifying the compatibility.
Apr 12, 2013 | Lenovo Ibm Thinkpad X230 Laptop Notebook...
Can't install expat shield on my windows 8 computer
Is it compatible? 32 or 64bit? Download the program to a folder and modify the compatibility, if you haven't already. It states it's compatible with Win 8. http://expat-shield.en.lo4d.com/ Here's a compatibility procedure : http://www.eightforums.com/tutorials/6832-compatibility-mode-use-windows-8-a.html
Mar 02, 2013 | AnchorFree Expat Shield
Drivers for IBM Netvista M42 2.26 GHz Pentium 4 Desktop 31U
I do apologize if I will not be able to lead you to the target page of the drivers download because your computer's machine type was not stated in your problem description. Anyways, here is the page to start with, Click Here. On the page where you land, select the machine type of your computer as stated on fig.1 below. After selecting your computer's machine type, load the drivers one by one by clicking on the link under the date modified as shown on fig.2 below, because there drivers that require a restart.
fig.1
fig.2
Thank you for visiting FixYa! Enjoy!
May 10, 2011 | IBM Computers & Internet
Please send me service and Schematic manual for IBM monitor E74. Thanks million.
schematic manual for monitors are not available.repairing a monitor dont need any schematics post the problem here will teach you how to do it. thank you!
Feb 17, 2011 | IBM E74 Monitor
IBM ThinkPad 560X UltraBase
Look at the bottom for the type (ex:570E is type 2464) but it looks like Thinkpads 380 & 385 are compatible
Mar 11, 2009 | IBM XSERIES 235 HOT-SWAP PSU CONVERSION...
Need help transfering data from IBM Aptiva to Dell computer
Sounds like the older computer is a 98 machine - Data Traveler does not have 98 drivers due to its size. Your best bet is to find a smaller flash drive that is 98 compatible - or depending on the size of the data you could e-mail it to yourself.
Jan 09, 2009 | IBM Aptiva E 240 (2158240) PC Desktop
DVD drive
Hi usually when the light stays on this means the cable is the wrong way round the same problem occures when you get the floppy drive lead the wrong way round.
If the dvd drive came out of a working computer then the jumper settings were probably correct if the cable can go the other way round try that.
The only other problem you can have is are you building an ibm compatible computer if you are is the dvd ibm compatible if this is also not the problem then the chances are the dvd drive is damaged.
Do you have a normal cd drive in and working if you do try using it in the place of this if this still dont work then i would say the unit is dammaged.
check the leads not damaged but what you are explaining sounds like the lead is wrong way round let me know how you get on ok
Nov 27, 2007 | Televison & Video
Apple M6496 17" CRT Monitor Logo
24 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
MarkMAlford
MarkMAlford
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
