Question about Linksys Wireless-G WRT54GS Router (e125894)
No power light, cannot connect
I've gone through the pattern of connecting the modem & router, but when I plug in the router's power cord there is no power light. The other port lights are visible. I even tried plugging it in to another socket and no light. My internet works when I by pass the router and just use the modem.
Any thoughts on how to get the router to work?
Thanks,
Karen
  • KarenTX Jul 30, 2008
    Status is "excellent".
  • 298 Answers
What is the status of the local area connection on your computer if its connected directly to the router?
Posted on Jul 30, 2008
  • Jeffrey Pedimonte
    Jeffrey Pedimonte Jul 30, 2008
    Okay its seems like its the wireless connection that you were able to check. How about if the computer is direclty (wired) connected to the router, what does it say for the LAN connection or local area connection. Does it still say connected or does it say cable unplugged?
How do i get my wi fi to work again? i've owned it for 14 months w/no problem. Now it wont connect although i'Ve got the same security (WPA/WPA2 PSK and password,It just working this...
First trouble shoot would be:
Connect your PC directly to the modem and see if you have internet access. If so, then just reboot the router.
If not, unplug the power from the modem and the router.
Plug the power back into the modem and wait 2-3 minutes (to make sure it talks to your service provider. Again - you can connect your PC to the modem and test.)
Then plug in the router and see if that connects (is there a light that indicates connectivity?)
If you did not change anything in your router setup, it should come back up.
If these steps don't solve the issue, please come back here and let me know.
Fingers crossed!
Jan 19, 2015 | Nextbook Tablets & eReaders
I cannot connect my Belkin 54g to the internet at all. I followed the wizard and got the information from my ISP - user name and password. The wireless light works, the port shows that it working but the...
ghost2233_6.jpg Did you connect the lan cable to the right port ????
1. Shut down any programs that are running on your computer at
this time.
2. Make sure you have the following items at the computer that is now
directly connected to the cable or DSL modem. DO NOT CONNECT THE
ROUTER AT THIS TIME.
• The Easy Install Wizard CD-ROM
• The Router
• The Router power supply
• Category 5 networking cable
• This Quick Installation Guide
3. Turn off any firewall or Internet connection sharing software on
your computer.
4. Insert the Easy Install Wizard software CD into your CD-ROM drive.
The Easy Install Wizard screen will automatically appear on your
screen within 15 seconds. If it does not, select your CD-ROM drive
from "My Computer" and double-click on the file named "Setup" on
the CD-ROM.
5. Turn on your cable or DSL modem by reconnecting the power supply to The Wizard will take you through the completion of the process.
the modem.
6. Before plugging the power cord into the Router, plug the cord into the
wall, then plug the cord into the Router's power jack.
7. Verify that your modem is connected to the Router by checking the
lights on the front of the Router. The green light labeled "WAN" should
be ON if your modem is connected correctly to the Router. If it is not,
recheck your connections.
8. Verify that your computer is connected properly to the Router by
checking the lights labeled "LAN 1,2,3,4". The light which corresponds
to the numbered port that you connected your computer to should
to the numbered port that you connected your computer to should be
ON if your computer is connected properly.
Good luck
Mar 12, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
How do you set the router up!!! no diagram to hook up to desktop
How you connect it depends on how you plan to use it. Let me explain:
Some people have a dsl line (high speed internet connection) and their modem from their internet provider only has room for one computer cable to connect and use the internet. If the customer has more then one desktop computer they want to connect to the internet, they will need to buy a router. A router provides multiple ports for several computers to connect to the internet at the same time.
If you have a dsl modem already and bought a router to add additional computers to your network - then follow the instructions below to set it up:
Connect your phone cord from the wall into the dsl modem. Plug in the power cable from the dsl modem to the wall and turn it on. Connect an ethernet cable to the dsl modem (ethernet cables are the ones that look like a regular telephone cord but the ends are a little larger) and connect the other end to your router. Make sure you plug this cable into the port marked "ethernet" on your router. There is only one port for your internet connection line coming into the router, the rest of the ports are for adding computers only. Some routers say the word "ethernet" near the port for the internet connection. Others have a picture near or or brackets around it to show that it is different then the others. Plug in the power cord to your router and turn it on. Make sure you turn on your modem first and let it warm up before connecting your router. Modem power on first, then router power on - always.
Now connect an ethernet cable to your router and connect the other end to the pc you wish to use on the internet. Do not turn on your pc until the ethernet cord is attached. Your dsl modem has to be powered up first, followed by your router and then your pc. All in that order.
Your computer should automatically sense the internet connection upon start up. You can verify that your connection is installed correctly and that your pc is sensing it by looking at the bottom right side of your screen near the clock area. You should see a picture of a computer monitor that represents your internet connection status. Sometimes they glow green when they are healthy. Sometimes they show a red X on top of them if they are disconnected from the internet. If you can't find the Icon for your internet connection on the bottom right side of your screen, unplug the ethernet cable from the back of your pc - while watching the bottom right side area and plug it back in again. Watch for a change to locate the icon. Sometimes there is a downward pointing arrow near the clock which needs to be clicked on to open up the area and view the icons.
Thats all! One line from the modem to the router - another line from the router to the pc - and the internet should be up and running fine.
If you bought a router combination modem - then its the same as above - just without a separate dsl modem. (i.e. Connect the power cable from the router/modem to the wall. Connect the ethernet cable to the port marked "ethernet" for your internet connecton and connect the other end of the cord to your pc. Then turn your pc on. Router/modem power on first and pc power on second in that order)
All the lights on your modem should be green and steady - except for the one marked internet or connection which is usually flashing and moving. If you have any red or yellow lights then you need to troubleshoot and correct the problem before your internet connection will work.
Mar 03, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
Unable to connect to internet through Linksys WRT160N router. Can unplug it and internet is fine. Tried power cycling the modem and router. Linksys comes up with all lights flashing and will not...
If I understand your problem correctly, you are able to connect to the Internet when you hook the computer directly to the modem, but not when the router is connected to the modem.
If this is the case, then you need to do a power drain on the modem. Power cycling the modem is not enough to clear the NVRAM of the MAC address of your computer. You have to unplug the power cord of the modem for 15 to 20 minutes in order for the NVRAM to reset and allow the modem to recognize the MAC address of the router.
After the modem has been unplugged for 15 to 20 minutes, disconnect the power cable from the router and then connect router to the modem using the Ethernet cable.
Next with the router power cord still disconnected, plug in the power cord of the modem and allow the modem to sync to the network.
Once the modem is finished with its start-up, plug-in the power cord of the router and let it sync to the network.
After the modem has completed its start-up, it should now be connected to the internet.
Good Luck
Dec 30, 2010 | Linksys WRT160N Wireless Router
Ethernet won't reconise modem for xbox live
Once you have everything hooked up:
Ethernet cord going from modem into wireless router in port labelend internet or wan, and an ethernet cord going from the router to the xbox you should try these steps:
Unplug the power cord on the modem and plug it back in- once all the lights come back on
Unplug power cord on router and plug it back in-
Hope this helps.
Apr 07, 2009 | Linksys Wireless-G WRT54GS Router...
Cant connect!
- Try to power cycle the Motorola modem and the router for 5 minutes.
- After 5, turn On first the modem, make sure all the lights of the modem are stable before plug in the router.
- If this procedure doesn't work then I suggest that you might need to update the firmware of your router.
Mar 15, 2009 | D-Link DI-624M Router (DI624MRE)
Wireless router stops internet connection to modem during install
are you sure your hooking the comcast modem in the right place?
Feb 08, 2009 | Arris SURFboard SB5120 Modem
Connecting my sony vaio laptop through my linksys router with dsl
Try this:
Connect the modem to the router, and the router to the computer.
Pull the power cord out of the Modem.
Pull the power cord out of the Router.
Wait 10 seconds.
Plug in the modem, and wait untill all the lights go steady (ususally a minute or two)
Plug in the router.
Check your connection. Ask for more help if this doesn't work.
Jan 09, 2009 | D-Link DI 514 Wireless Router (DI-514)
Buffalo router
Let me verify your network configuration with you. You have your modem connected to the WAN/Internet port of your router via an ethernet cable and then your PC connected to your router via another ethernet cable, correct?
If this is your setup, then try this:
  1. Unplug the power cord from the modem & router
  2. Plug the power cord into the modem and wait for it to boot up (most modems have an "Internet/Connection" light to indicate they are connected to the ISP)
  3. Plug in the power to the router, wait for it to complete the bootup process (usually when the lights stop flashing it's done), and see what happens.
Feb 09, 2008 | Buffalo Technology (WYR-G54) Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
71 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
