Question about Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Hello my cd/dvd rom doesnt work. it doesnt read anything i put in it and i dont know where to get a new one.how can i fix it?
    President:
  • 80 Answers
Try this before you buy a new CD/DVD Writer.
Step 1: Start Registry Editor loadTOCNode(3, 'whattotry'); Start Registry Editor.
Click on Start button than click on run and type in regedit and click on OK. (FOR WINDOWS XP)For windows Vista just click on start and type regedit on your keyboard and press ENTER.
Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'whattotry');
  1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
  2. Expand SYSTEM, and then expand CurrentControlSet.
  3. Expand Control, and then expand Class.
  4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
  5. In the details pane of Registry Editor, on the right side, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only.
    • If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
    • If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
  6. On the Edit menu, click Delete.
  7. Click Yes when you receive the following message: Are you sure you want to delete this value?
The UpperFilters registry entry is removed. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'whattotry');
  1. In the details pane of Registry Editor, on the right side, click LowerFilters.
    Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
    If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  2. On the Edit menu, click Delete.
  3. Click Yes when you receive the following message: Are you sure you want to delete this value?The LowerFilters registry entry is removed.
  4. Exit Registry Editor.
Step 4: Restart your computer loadTOCNode(3, 'whattotry'); Restart your computer. After you have done this, try to access the CD or DVD drive. If you can access the CD or DVD drive, and if you do not receive an error message, the problem is resolved. You can reinstall your CD or DVD writing or recording software.
Posted on Dec 28, 2008
My daughter has a C551 NR running vista. The CD\DVD Rom stop working in Vista so I used an external CD drive to install Windows 7, works great. . I ordered a new drive upon HP recommendation 435778-001....
should recognize the cd rom /dvd unit automatically
lower picture is of the c300 cd unit
anything look different from the original ............lowest picture
CRX880A Compaq Presario C305LA C508US C551NR Optical Combo Drive CD-RW DVD- ROM
Apr 17, 2017 | Compaq Creative Sound Blaster PCI 128...
CD DVD ROM doesnt read dvds when i insert the disk the light turns on i can hear the dvd turning but later on it stops. turn and stop again. then it doesnt read the dvd anymore
how long have you been using this CD ROM? I suspect the laser (lens) of the CD ROM. I think the laser (lens) is weak that's why it cannot read data/files on DVD.
To confirm if actually its a laser problem, insert an Audio CD into the CD ROM and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the CD ROM cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new CD ROM.
Good luck...........
Mar 18, 2011 | Toshiba 100GB Laptop for Satellite 2400,...
This drive reads a dvd but not cds. do you have
may be it's only a DVD ROM drive not a combo,
you will need a combo to read both DVD and CD
if it was reading CDs earlier then the CDs might have scratch in them, try with new CD.
did u make changes to the cables inside, if you did check if the cabels are connected properly to the drive
Dec 06, 2009 | Sony DDU1613 16X DVD-ROM Drive, Black...
LG cd-rom crd 8482b Doesnt Read Dvd's
well if its new i would say return it, if not then i would suggest to use canned air and blow out the inside of it and try it again. if that don't work then i would recommend getting a new one.
Dec 04, 2009 | Computers & Internet
Internal samsung cd-rom sn-124 doesnt recognize cd's/wont work
replace it. samsung cd rom even its dvd writer have lots of problems. sometime they dont want to open unless you leave a cd in it. sometime it doesnt read cd. better change it. get a Sony, LG, Pioneer DVD writer.
Aug 20, 2009 | Computers & Internet
Help
the lence or other ckt part of cd writer is got some fault
call to warranty check or local service station,dont waste time
regards
prasana
Mar 03, 2008 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
My acer
How long has it been giving this problem, if its less than a cpl days you can try restoring to a previous date since some viruses ca cause that problem. If that doesnt work or your system isnt infected then i guess your drive is dead and you will need to get a new one... you could also try your drive on another computer, to ensure its dead.. Let me know what happens..
Dec 30, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Compaq armada e500 dvd rom doesn't work
Try cleaning the lense using a lense cleaning disk.
Unfortunately it sounds as the drive is on the way out :(
Dvd are harder for it to read than cds so they are normally the first thing to stop working.
Dvd/cd drives dont require drivers as they are plug and play (aka plug and play!! :)
Best not to update the firmware as if it goes wrong then the drive will be dead.
Dec 28, 2007 | Compaq Armada E500 Notebook
Windows
hard drives dont read cd's
does the door close?
if not close it.
1)left clik my computer
2)double clik the cd rom drive, making sure theres a disk in it.
3)right clik on my computer
device manager
look for a yellow exclamation point or red X where the cd-rom is.
high light the cd-rom
right clik
uninstall
restart the computer
windows will detect and re-install the cd-rom drive.
try a cd
if that doesnt work update windows
also buy a cd-rom cleaner at your local electronics store
clean the drive w/th cleaner
try a cd
if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
Not working
Is the drive connected propperly ?
look at the jumper settings if its IDE
if it is connected propperly and still doesnt show up
( verify its showing up in My COMPUTER)
try it on anoter PC to see if it works.
Just cause its new doesnt mean it works
If it works and you did connect it propperly the let me know
IS IT READING ANYTHING ?
Is IT SHOWING UP IN YOUR DEVICE MANGER?
Click START, (right Click) my computer, select properties then device manager, it shoud show up in DVD/CD-ROM drives
if it doesnt then right click on anything and scan for hardware changes. If it doesnt show up then it isnt connected propperly.
Oct 13, 2007 | LG GSA-E10L (8801031212552) DVD±RW Dual...
Dell (1G055) CD-RW/DVD-ROM (Combo) Burner Logo
124 people viewed this question
Alun Cox
