Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Low Ink I just changed out both black and color ink cartridges 2 days ago and it is already saying the black ink is low, and the copies are quickly fading.
I get that when I have just refilled the cartridge, but I usually ignore it and it is still ok for a while; have you checked that you are using draft or normal not best settings?
Posted on Aug 06, 2008
Why when press color copy the non color not print are not being printed
If your question means that you are not getting "nice" color copy ... it may be possible that your (color) ink is running low or empty. For instance, if your black ink is low or empty, you will not get the black colors printed ...
So, check to see if your ink cartridges are running low or empty. And if so, see if a (new) replacement cartridge will give you the same result.
Aug 16, 2014 | Office Equipment & Supplies
Put brand new lexmark 28 cartridge just 4 days ago. Maybe used 10 times. Computer says ink is low and won't print anymore. However, can still make copies.
It could be just a slight communication failure between your cartridges and the printer. Try to re-seat the cartridges by removing and re-inserting them into the cartridge carrier.
I hope this helps.
Mar 02, 2012 | Lexmark X2500 All-In-One Printer
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
ESP9 color prints begin coming out purple like
Use only original ink cartriges, the non original has ink normaly is not for you printer, and you wast your money and damage the printer print-head
Jan 02, 2010 | Office Equipment & Supplies
I installed brand new ink cartridges and saying its low ink
Had another thought!!! unplug from mains for 30 min and retry.
Dec 11, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Ok I have a cx8400 all-in-one Epson printer. I was out of black ink so I started using composite black. Also ran out of color ink so I bought the black cartridge and installed it. Now the printer says i...
If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement. You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expendedI have come across this issue many times and unforunately you have to replace the colour carts in order to continue to use the printer.
Sep 12, 2009 | Epson CX8400 All-In-One InkJet Printer
Printer Always Indicates Ink is Low or Cartridge is Incorrect
To get rid of the low ink warnings google the specific error message with 'ink refill' and look for 'engineers reset' or similar ..
NB. Dell printers (re-badged Lexmarks) are notorious for ink usage and high costs .. so my best recommendation would be to throw it away and purchase something else ..
Nov 30, 2008 | Dell 922 All-In-One InkJet Printer
MFC-240c ink erros. says i'm low/out after replacing
Your printer detects ink levels with an optical sensor that shines at the clear plastic in the center of the bottom of the cartridge. Once this area is no longer dark it will tell you to replace the ink. Since you installed full cartridges it could be that the sensor is cracking up. Another possibility is that you could have air in the ink lines that run between your cartridges and the print head. When this happens the printer cannot print the color that has air in the lines. You should be able to look in your printer to see the ink lines and see if there is air in the black one.
May 31, 2008 | Brother MFC 240C All-In-One InkJet Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
