Question about Whirlpool Dryers
We just recently got a duet dryer and just installed it and when I tried to turn it on it shows all the settings and lets me choose but when I try to press the hold to start button it just beeps and the time number flashes and it does not turn on...what does this mean?
    Genius:
  • 1,028 Answers
Possible door switch but that is probaly not the only possible cause but easiest to verify
Posted on Jul 30, 2008
Aeqa000fg0 model dryer won't reset after leaving unplugged for an hour. When i plug it in, it shows all the settings and will let me choose the setting i want to dry on, but after a few seconds the drum...
Unplug for 5 min they re plug it in again and try to start it. Any difference? You did that. Seems the electronic board is not responding.not resetting. You might be in for a new board likely.
If the dryer is more that 5yrs, I would consider a new.
Oct 17, 2013 | Frigidaire Dryers
I have a Whirlpool Duet Dryer that is locked on the heavy duty cycle, I cant switch to another setting, it wont cancel out. I've tried unplugging it for some time to reset it. It is still stuck o
when you unplug it you're resetting the computer board just like your house computer does,so if it helped by unplugging it i would have to say the board is bad and needs to be replaced.next time send the model number off of the machine
Feb 02, 2018 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Machine powers up,,,than the whole machines powers down
Let's see if we can get it into diagnostic mode and check for any fault codes. Make sure the dryer is in standby mode, plugged in with all the indicators off. Select any button except the PAUSE/CANCEL button. PRESS/HOLD 3 SECONDS > RELEASE FOR 3 SECONDS > PRESS/HOLD 3 SECONDS > RELEASE FOR 3 SECONDS > PRESS/HOLD 3 SECONDS. If test mode was entered successfully all indicators will illuminate for 5 seconds with 88 showing in the two digit display. If there are no saved or active fault codes all indicators will momentarily turn off then stay on with 88 in the display. If there are any fault codes, the most recent one will alternately show F- and "XX " where XX is the fault code. and all the cycle indicators will flash. If you can't enter the test mode try a different button. Lets start there.
Nov 17, 2012 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a Whirlpool electric dryer, it is a Duet with a model # of: GEW9250PW1. When I try to select the the "normal" setting on the automatic side, it lights up the delicate light and has the...
Is the selector knob loose on the stem? Look on the knob to see if there is a set screw of some sort that you can tighten to set it where it belongs, it just seems it's loose and isn't pointing to where it should. Let me know if this works or not,
Please rate and comment, Thank you,
Joe
Sep 01, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Replaced the thermistor, now the panel timer read out works, but when trying to start dryer, it will not run
try the door switch in the dryer inside of dryer its a button that close a switch to let power pass through to turn the dryer on if need help let me know
Apr 13, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer kicks off circuit breaker, pf code is on dryer. now won't let me do anything
pf is for power failure. sounds like You may have a short somewhere. Be careful of electric shock.
Apr 21, 2009 | Dryers
try holding button down next to the small lock emblem for 3-5 sec
Aug 27, 2008 | Dryers
Open Questions:
Dryers Logo
46 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
