Question about KitchenAid Dishwashers
I have kitchenAid KUDM24SEWH5. The door opens with no resistance. I assume the door spring came loose or broke. How do I check this out?
    Novelist:
  • 116 Answers
If you remove the toe kick panel and look at either side of the machine you will see a lower frame rail near the floor. If you look at the upper and lower edges of the toe kick you should see 2 or 4 screws which are typically used to hold it on. Under the panel on either side there is a spring clipped to the frame rail about 4 to 6 inches from the front. This is the door spring. It attaches on an arm the is at a 90 degree angle from the front door panel. There is one on each side.
Alternately you may pull the dishwasher out from the cabinet to reattach the spring if it is loose. If you open the dishwasher door and look upwards under your counter top near the top of the dishwasher you should see two screws which fasten the dishwasher to the cabinet. Some models have side screws but most just have the top. With the screws out you should be able to bull the dishwasher straight out from under the cabinet. Do not use the door to pull as you could pop it off of the hinges. You will only have to pull it out 6 inches or so to see the springs and mounting positions.
Posted on Jul 29, 2008
Door falls open
The cables that are connected to the springs are broke, atleast one anyway. You'll need your model number off the machine to get them from a parts dealer. once you have them, pull the machine out a little ways and they install on the left and right side lower area.
May 28, 2012 | KitchenAid Dishwashers
I opened the door on my dishwasher heard a pop and now the door is heavier and droppes open?
One or both of the door springs came off or broke. If you take off the bottom panel you should be able to look with a flashlight and see.You can buy the springs and replace them.
Apr 06, 2011 | KitchenAid Dishwashers
Dishwasher door falls open/no resistance as it opens. What broke?
the spring either came unhooked or otherwise fell off - you should be able to unhook the mounting bracket, lower the front legs and pull the machine out a bit -- BE CAREFUL TO SEE YOU HAVE ENOUGH LENGTH OF WATER LINE, DRAIN AND ELECTRICAL BEFORE YOU MOVE IT OUT - once you gain access, check alongside the machine you will find your problem..
Ck
Feb 13, 2011 | KitchenAid Dishwashers
Kitchenaid dishwasher model# KUDM24SEWH5
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
qqqr
Apr 18, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
I have a KitchenAid dishwasher. The door drops
either the door springs are broke,worn out or possibly the door balancers need replacing
Jan 10, 2010 | Dishwashers
Soap dispencer not opening. Feels like spring broke
Should be easy to check the spring. When the door is open does the dispenser door spring back? If not it may just be that the spring has come loose. Disconnect the power. Most dishwashers have screws down the door sides to remove the front panel. Gently remove it and check the spring hasn't just come off the dispenser
Oct 03, 2009 | Dishwashers
Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Mar 26, 2009 | KitchenAid Microwave Ovens
Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Jan 19, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Broken Microwaive Door
I'm assuming your correct model number is KCMS145JSS? You have a broken "release lever", part number AP3033332. It's reference number 7 on the exploded view diagram found here: http://www.appliancepartspros.com/sect/4/g/4/4g4rya32jj.gif You can order it by part number from Appliance Parts Pros here: http://tinyurl.com/gv383 If needed, you can download the owner's manual and installation guide here: http://www.kitchenaid.com/custserv/literature_search_results.jsp?searchTerm=kcms145jss If you need further help, please follow up. I appreciate your rating of this answer.
Nov 17, 2006 | KitchenAid KCMS145J Microwave Oven
Dishwashers Logo
220 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
