Ipaq 211 plugged in to pc says usb device not recognized
I moved my pc when got a new computer desk. Now when plug in IPAQ 211 says USB device not recogonized Seem like when 1st got IPAQ had to configure USB?? Now HP want 49.00 to help again software support expired. Please tell me what need to do.
Running Windows Mobile 6, yes have deleted and reinstalled this software
Help
Gwen
I have a fairly new HP iPAQ RX3115. I bought the charger today which also came with a USB cable to plug my iPAQ into my computer. When I connected my iPAQ with the USB charger, and plugged it in the...
2005 new, 12 years old, is new? really, and is no longer supported by HP, after 10 years.
my guess is the battery is toast,
never seen any battery last 12 years, ever.
not by a mile.
this thing has no value now.
if its LOVED, (why) then buy 2 and learn to fix them.
be like only on earth wanting to...
why not get a tablet.? modern.
here is all there is. RTM and get a new battery first.
http://support.hp.com/us-en/product/HP-iPAQ-rx3000-Mobile-Media-Companion-series/437953/model/437919/manuals
r
Mar 02, 2017 | HP iPAQ RX3115 Pocket PC
USB connection to PC problems
You must have ActiveSync installed and running on your WinXP PC, for a WM device to be allowed to synchronize its data. Just in case your PC happens to be missing it, you can download it from this location.
Hope it works for you.
Cheers! Carlos
May 09, 2010 | HP iPAQ hx2190 Pocket PC
My sony desktop will nolonger recognize my ipod or my camera when I plug them into the usb port. It will however recognize my blackberry and my Ipaq. Please help
I assume you are running windows operating system. You need to uninstall all your usb devices. Go to computer manager/device manager and select all USB devices and unistall them. Go to the start menu, click on run type compmgmt.msc. Find all your USB devices on the right side. Follow the instructions for each device to uninstall them by double clicking and then select uninstall. once you uninstall, click on the icon to scan for hardware changes located on the sub menu. Your operating system should recognize new hardware or reboot and the operating system should install them automatically ageain. Try this, I hope it helps.
Mar 09, 2009 | Sony VAIO PCV-W600G PC Desktop
HP iPAQ 2215 sync problems with Vista and Windows Mobile 6.1
I've decided to get a smartphone with Windows Mobile 6.1, so this issue has been "solved"
Feb 08, 2009 | HP iPAQ 612C Smartphone
Pc doesnt see ipaq h6315
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Apr 19, 2008 | HP iPAQ h6315/h6365 Pocket PC
IPAQ H5555 connection problems
Hi, This could be due to a few issues, try these soloutions in order below: 1) If you have a jacket connected to the ipaq it could be preventing the ipaq from locating correctly on the connector. Remove jacket and try insering again. 2) Check that active sync is set up to detect the device on the usb port. The cradle for the ipaq may have a serial and usb connector. Ensure that just the usb connector is attached to your laptop. Try connecting again. 3) You may need to uninstall the USB cradle if it was connected before installing active sync. Try the following steps if this was the case: a) unplug the USB cradle b) uninstall active sync c)Click start then click control pannel then click system. Then click on the hardware tab. Look for the device under USB, right click on the device and then select uninstall. d) restart the laptop e) Install active sync f) ONLY after active sync has installed you can now plug the cradle back into the usb socket. g) Now connect the ipaq, it should now detect it.
Aug 09, 2007 | HP iPAQ H5555 Pocket PC
IPAQ H5500 USB CONNECTION TO PC NOT WORKING
open active sync on ipaq and connect the cable with pc and ipaq. if not recognised perform a soft reset on ipaq. also check in  active  sync on pc >file> connection settings> allow usb connections is checked
Jul 20, 2007 | HP iPAQ H5555 Pocket PC
IPAQ 1715 not recognized
All you should need is Activesync. Try the following... From your PC .......... with IPAQ cradled click on Start, Control Panel Double-click on System Click on Hardware, then Device Manager Click on '+' to left of Universal Serial Bus Controllers Click on '+' to left of Windows CE USB Devices Right Click on HP USB Sync Select 'Uninstall' Uncradle IPAQ Reboot PC
Sep 08, 2005 | HP iPAQ RZ1715 Pocket PC
Can't connect EM500 to my laptop computer
It sounds like you are using two different types of USB connections, one for the iPAQ and the other for the Casio. What operating system is running on the laptop? How many USB ports are there? You might have to reboot when you want to change from one USB connector to the other. If you have two USB ports, always connecting a USB connect to the same port (iPAQ #1, Casio #2) might help the OS keep track of what is connected to it.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
