Question about HP Photosmart C6180 All-In-One InkJet Printer
Photo tray output problem
Hi, my printer is used for home based business and suddenly is not printing. it keeps prompting to put output tray all the way down but it already is. it is a c6180 I have the same problem. So what is the fix?
  • 1 more comment
  • ksilinux Aug 03, 2008
    Exactly the same problem. It won't print out of photo tray. Asks to put the tray all the way down, nothing helps.
  • mommacita50 Feb 10, 2009
    Same problem...printer won't work, asks to push down output tray, but it is down...what's the problem, can someone help
  • Anonymous Mar 13, 2009
    I have the same problem with a HP C7180. Says to put the tray down. So far as I can tell it is. It just makes this hideous grinding noise.
I fixed it just now and easiest, following the step below:
1) Can you see the blue thing between the paper tray and the printing tray? That's the Output Tray! Just press it back in as much as u could
(but don't break it). Then you trying print (testing), they might have a paper jam but its normal. After the jam, they will tell to dismantle the jammed paper at the back.
2) Shut down (or restart) your printer (unplug the power switch or it won't work). Plug it in again and then just simply its done!
3) If it won't work, repeat the previous step again... Good Luck ;)
Posted on Oct 22, 2010
Why does it say no paper? The tray is full. I'm working from an iPad air2.
most likely it is not picking paper, not that it doesn't have paper.
look down into the printer from the front where your paper goes and watch it when it tries to pick up a piece of paper. if the rollers are dirty with dust or such they aren't as tacky as they should be and aren't getting ahold of the paper. get a dab of dish soap on your fingertip and get it on the pick up roller and scrape at it with your fingernail. you will see the dirt coming off of it. wipe it off with a damp cloth and let it dry. it should be stickier than it was and be able to grab paper now.
Feb 09, 2016 | Canon PIXMA MG3520 Wireless Inkjet Photo...
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
My HP C6180 stopped printing photos. I am using
buddy download service pack 2
:it will fix the problem
Jul 04, 2009 | HP Photosmart C5180 All-In-One InkJet...
Will not print photo from main tray
The printer will automatically select the "Print Quality" Media based on its driver settings or the device settings.
You will need to access the properties of your printers software to assure that you have selected photo paper for the tray you wish.
Depending on which model of printer your using, you may have to access the Settings/Options/Page Setup/Tray Setup Menu. Consult your Owners Manual for settings these Tray options. Make sure you have set the tray you wish for Photo Paper (or comparable quality option)
Let us know
Good luck
Apr 14, 2009 | HP Media Center m7250n (ED842AA) PC...
My printer c5280 keeps saying please reinsert or lower photo tray
If it is asking for photo paper you should be able to hit ok on the screen and then it should go to the default screen and be ready to print.
Jan 17, 2009 | HP Photosmart C5280 Printer
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Paper output tray is closed
I had the same problem with the paper output tray. I solved it by removing the switch by removing one screw and tying the wire leads together. Now the printer thinks the tray is always open.
Dec 31, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
554 people viewed this question
Ben Johnson
