Question about Miele Vacuums
I have a Miele s251i vacuum that was working just fine until I umplugged it (while running) and re-plugged it in at a closer socket. When I replugged it, it started for a second and then stopped. Will not start now whether we use the on/off switch or not...suggestions? Would also like to know how to disassemble the unit so I could check out the wiring with a multitester..thanks
I just had exactly the same problem. Opened the vac, checked the circuit next to the motor and it can be clearly seen that the Triac burned thru the PCB. Will replace it and check again. Vac bought long ago, works extremely well.
Posted on Aug 29, 2010
Cost to replace a motor on a miele s251i
Buy a new one. Motors cost almost as much as the unit.
May 03, 2014 | Miele S251i Plus Bagged Canister Vacuum
Power can't be turn on
could be a bad plug end you can cut it off attach new plug. If that dont work new rewind or bad electronic board
Oct 27, 2013 | Miele S251i Plus Bagged Canister Vacuum
Stopped working while vacuuming...less than 2 years old???
Hi, It's probably the cord. I do wish Mieles were more durable given what they cost. I clean a home 3x per week with a Miele and tend to go further than i should before i unplug and find a closer outlet to plug into. So, it's the tugging on the cord that killed it. I had to take it to a Miele certified repair shop and they replaced the cord itself, which of course had a new plug on it. It was around 60 bucks. The owner didn't speak great English and I don't know Spanish so i'm unsure where the prob was: the spot where the cord attached to the vac, or the plug. In any case, I don't tug on the vac anymore....owner's were unhappy. Lesson learned.
May 14, 2010 | Miele S251i Plus Bagged Canister Vacuum
Miele vacuum powerhead
My power head failed due to the handle switch. It comes apart with the Phillips screw under the vacuum kill slider. Check for continuity across the switch contact solder points.
Mar 01, 2010 | Miele S251i Plus Bagged Canister Vacuum
The Miele S251i just stopped working. Is there an
How long has unit been down? There is a inline fuse by motor housing internally in unit, but sometimes these units take awhile for them to reset
Dec 03, 2009 | Miele S251i Plus Bagged Canister Vacuum
My vacuum (miele s251i) will not turn on. I just changed the filters and bag. Just wondering if I have put the top filter in the wrong spot. Does it go under the black flip-up bit or on top of it? I do not...
Hello Miller_04,
Regardless of how the filter is put in the vacuum cleaner should turn on. Really is no way to put the filter wrong in these. I have a white star myself.
You can contact Miele Vacuum support and they can further troubleshoot or recommend a vacuum shop in your area to send it to for repairs
Miele Dealer Locator (vacuums: non repair)
(800) 579-4583
Monday-Sunday: 24 hours Miele Dealer Locator (vacuums)
(888) 785-2828
Sep 16, 2009 | Miele S251i Plus Bagged Canister Vacuum
Access to the Plug in Cable of Miele White Star Vacuum Cleaner
Problem solved. A guy posted on the internet a step by step explanation including photos of how to open a Miele White Star vacuum to get to the take up reel.
May 13, 2009 | Miele S251i Plus Bagged Canister Vacuum
Meile s251i won't turn on
Hi If the power head isn't working it may be clogged. Try taking it apart to see if threads and general dirt has got in at the sides. Also without the power head if the Miele still isn't working then its a possibility that the on switch wiring is either loose or check the plug at the end of the power cord.
Mar 26, 2009 | Miele S251i Plus Bagged Canister Vacuum
Will not turn on
Your problem is probably a bad male cord end or the there is a problem with the cord winder. It might need a spacer.
Aug 16, 2007 | Miele S251i Plus Bagged Canister Vacuum
Vacuums Logo
412 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
