Question about Dell Dimension 2400 PC Desktop
Replaced hard drive
I lost my hard drive after running Norton Disk Dr with the "Automatically Fix Problems" box checked. After running it, my computer wouldn't recognize that I had a hard drive anymore. Symantec said I must have a corrupted boot sector. Dell couldn't even get the diagnostics to recognize that there was a hard drive. Anyway, I replaced the hard drive this weekend, and have reloaded Windows and my drivers, and downloaded my updates, etc. My question is: Can I hook up my old hard drive as a 2nd hard drive to possibly retrieve some of the info on it that I didn't have backed up, or is it all a lost cause?
    Problem Solver:
  • 42 Answers
Try connecting it as slave and after rebooting the system, your harddrive may be recosnise by the system. after copy the data and format this HDD in low level.
Posted on Jul 30, 2008
Norton 360 Premier Edition
You might have to uninstall the current version you have on your computer thenrestart your computer.
Run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
You might also do a disk clean up click start click on computer to open right click on your hard drive usually C: select properties in the general tab select disk clean up click ok you can view files to be deleted.
Then reinstall.
Feb 26, 2014 | Symantec Norton 360 Version 2.0 Premier...
How do I fix currupt data
I believe you mean "corrupt data". When we have message corrupt data means that something wrongs with hard disk. You can try correct problem running full disk check.
Check your hard disk for errors
You can help solve some computer problems and improve the performance of your computer by verifying that your hard disk has no errors .
Open Computer by clicking the button " Start " and then click Computer.
Right-click the hard drive you want to check, and then click Properties.
Click the Tools tab , and then , under Error-checking , click Check . Administrator permission required If you are prompted for an administrator password or confirmation , type the password or provide confirmation .
To automatically fix problems with files and folders that the scan detects , select Automatically fix file system errors . Otherwise , the disk check will report problems but not solve .
To run a full disk check , select Scan for and attempt recovery of bad sectors . This scan attempts to find and repair physical errors on the same hard disk and may need more time to complete .
To check for errors in both files and for physical errors , select both check boxes AutoCorrect file system errors and Scan for and attempt recovery of bad sectors .
Click the Start button .
Depending on the size of your hard disk , this process may take several minutes . For best results, do not use your computer for other tasks while it lasts error checking .
note
If you select the Automatically fix file system errors for a disk that currently in use (for example , the partition that contains Windows), you will be prompted to reschedule the disk check for the next time you restart your computer your .
Jan 29, 2014 | Toshiba Computers & Internet
Fix it problems
You could run the chkdsk disk utility
Windows 7 chkdsk
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html 5E3422139C19CBED35C14826A44D4605
Jul 14, 2013 | Computers & Internet
Hard disk with errors
click start run type cmd then type chkdsk/r/f which will scan for and attempt recovery any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now
click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start should schedule this task when restart if its the hard drive with your operating system
i have found best results tick one box then return after it has completed then tick the other box for usb drives
do not do anything while the chkdsk utility is in progress any input may damage this drive
then defragment your hard drive
hope this helps
Apr 20, 2012 | Gateway M-1624 Notebook
Is it a common issue that the wd Scorpio blue drives have Read/Write head problems? and also problem with bad sectors?
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
click start righy click on my computer you should see your drive select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start tick in two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive also download and run a registry cleaner cc cleaner is 100%free
http://download.cnet.com/ccleaner/
hope this helps
Aug 17, 2011 | Western Digital (WD6400BEVT) 640 GB SATA...
MpKsl52d965d9 and MpKsl6043a131 are not working properly
what sort of problems have encountered ? can you see your hard drive
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer hope this helps
Jul 04, 2011 | Toshiba NB505N500BL 1 GB Hard Drive
I HAVE A SEAGATE BARRACUDA LP 1TB HARD DRIVE THAT KEEPS SAYING HARD DRIVE NEEDS TO BE REPAIRED OR REPLACED AS MY WIFE BACKUPS HAVE NOT BEEN WORKING AND IT APPARENTLY RAN OUT OF BACKUP DISC AND DAMAGED THE...
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility:
click start righy click on my computer you should see your drive select properties click tools check now tick both boxes automatically fix files and scan for and attempt repair on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
(it will only schedule on restart if there is an operating system on the drive)
hope this helps
Jul 04, 2011 | Seagate Computers & Internet
I have a 6L300R0 hard disk, i brought it set it up got running at 300gb as expected after a short time i had a problem with cross-linked files which i had to relinquish. I deleted the drive which was on...
do not do anything while the chkdsk utility is in progress any input may damage your computer hope this helps dont forget to vote
Mar 11, 2011 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
Hard disk common problems
first up
also
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 24, 2011 | Samsung HM500JI 500 GB SATA Hard Drive
I have an error17code how do i fix
Error 17 takes place when the system is misconfigured or its essential files are missing. Such problems occur when a PC is not maintained properly and has accumulated many critical issues that require immediate repair.
hope this helps
Jan 05, 2011 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
70 people viewed this question
Alun Cox
