Question about Honeywell Programmable Thermostat Heater
Honeywell programmable thermostat
We set our temp on the thermostat (air conditioning) and the temperature will reset by itself to a different temp. We do not have it programmed at this time. We set the temp and that is it. It changes randomly to different temperatures a few times per week.
  • Anonymous Aug 20, 2008
    I DONT KNOW HOW TO OPEN THE TERMOSTAT TO CHANGE THE INTERNAL BATTERY I LOST THE MANUAL
  • Anonymous Aug 31, 2008
    same as above
It sounds like you might have the same problem that we have. I read the manual and it says that thermostat has a special lock to prevent tampering. It could be locked. If you override it only last a while and goes back to its original settings. The manual says you need to contact the person who installed it. In our case the person who was in charge when when we had it installed is no longer with the company. We don't know who installed it.
Posted on Aug 07, 2008
I couldn't figure out how to amend my last question, so here is one more piece of information. I just put batteries back in and reset the time/date. The Temp Up and Temp Down buttons WORK FINE
your thermostat may be locked go to honeywell web site punch in thermostat model # and look for set up pushing two button at the same time gets you in but you will need instuctions for set up
Jan 31, 2015 | Honeywell RTH230B 5-2 Day Programmable...
What extent AC do I requirement to cool my chamber?
The regular is actually 3500 in order to four thousand Btu's associated with air conditioning have to make up for the quantity of temperature created with a one thousand watts lighting. Instance: ten By one thousand watts lamps will need among thirty-five, 000 as well as forty, 000 Btu's associated with air conditioning. Five By one thousand watts lamps will need among seventeen, five hundred as well as twenty, 000 Btu's associated with air conditioning. They are common recommendations because space circumstances, background air flow temps as well as air flow techniques almost all differ.
Oct 04, 2014 | Heating & Cooling
Trying to set temp on honeywell t-stat
I believe what your experiencing is the 75 degrees is the hold temp position...the display then reverts back to the actual room temperature...it doesn't mean the set temperature changed back to 65 degrees. Try to reprogram the thermostat schedules, and try not to use the hold function...just the temporary hold. (which is bumping the programmed temperature up or down until the next programmed period)
Dec 09, 2013 | Honeywell Programmable Thermostat Heater
How do I set the temporary or permanent override feature on the Honeywell RTH2310B model thermostat?
To set the temporary override, press arrows up or down to desired temp. This will keep temperature
at temporary setting for 2 hours then return to programming. To permanent override press MODE button until schedule period number disappears (number inside little house on stat). Then adjust temp with arrows. Press the MODE button again to cancel override and return to programmable.
Jan 25, 2011 | Honeywell Programmable Thermostat Heater
My thermostat when prgrammed and set on "auto" mode kicks on heat when temp drops below set temperature. The problem is that after warming up to that temperature...it does not shut the fan off. ...
I have a honeywell TH8320U thermostat and American standard Air handler with heating unit put in. THE thermostat works fine with the ac and follows the programs I have set. However the heat is a different story. The thermo clicks on to follow program but the unit does not run. (auto settings) If I place the thermo in heat and turn it to on I get heat?
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
I have a Honeywell programmable Thermostat (an expensive one that handles humidity, etc) and every spring and fall the thermostats behave improperly by ignoring the programmed temperature and cooling the...
What is the model number of the thermostat? What may be happening is the humidity control is trying to satisfy the humidity setting by running the a/c. In the installers set-up, there should be a setting to determine how long the system should run to satisfy humidity setting. I typically set thermostats for a 3 degree droop. Meaning it'll only drop 3 degrees below set temp. Also check your humidity setting to be sure it's not set too low. It should be set between 45% and 50%.
May 03, 2010 | Honeywell Programmable Thermostat Heater
Problem with Honeywell HCW80
The thermostat is mounted in front of a hole and a void in the wall. A draft of air may be coming in from this void, where the wires are in the wall. It should be sealed so the thermostat keeps accurate temperature.
Thermostats temperature reading can be calibrated if the reading is off, as indicated by the thermostat's installation manual
Jan 11, 2018 | Honeywell Heating & Cooling
Cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Non-deletable schedule in VisionPRO TH8000
The thermostat has a function called "Adaptive Intelligent Recovery".
This feature allows the thermostat to learn how long the furnace and air conditioner take to reach programmed temperature settings, so the temperature is reached at the time you set. For example: Set the Wake time to 6 am, and the temperature to 70°. The heat will come on before 6 am, so the temperature is 70° by the time you wake at 6.
You can turn off this function. Download the installation guide at the next link:
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH8321U1006
and look for funcion number 0530 Adaptive Intelligent Recovery. In this manual you also find the way to do a reset with the function number 0710.
I hope this solves your problem.
Nov 19, 2008 | Honeywell Programmable Thermostat Heater
Loss of temperature control
Is the heater staying on all the time? Most likely cause of themostat trouble is the sensor. Try to find it and measure its resistance at different temps to verify the trouble.
Dec 31, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
258 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
