Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
3 inch blank space at top and bottom of 50 inch projection hitachi ultra vision
What cause a 3 inch blank space at the top and bottom of screen.
It does it on all channels, right now, the bars are not there, but if you turn the tv off, then back on, they are there for about two days, then they go away. We don't turn the tv off, we just change the input off, then change it back and the tv is working fine, but as soon as you turn it off or have a power outage, the bars show up again.
Posted on Aug 02, 2008
  • 927 Answers
Good Day, richardyoung;
Lack of vertical reflection? Does this happen on all channels? Can you change channels and the picture size changes? Are you receiving a HD signal? Have you tried changing the format?
I hate to ask you all these questions but I need to understand your concern completely. If you answered some of questions above yes / no; your TV might be okay. But try them.
Good Luck, big IRISH.
How to fix horizontal lines across screen and black bar at bottom?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes are given with illustrations. You can get an idea about the fault to an extent. Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Oct 22, 2015 | Sony SLV-695HF VCR
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
I run on Windows XP, pack3 and I use a CRT ViewSonic EF70 ... 17 inches The screen is not filled completely with the image from Microsoft Internet Explorer, nor with Outlook Express .... there is about 3...
two things you can do, first right click on your windows screen and look for "settings" this will open a dialog box where you can set the screen resolution. Set it lower and see if your screen is now filled. if that doesn't work go into the monitor setup (buttons on the bottom or side of the monitor) and try to set the verticle and horizontal size, since its only 3/4 of an inch you should be able to stretch the screen to fill up the space.
Mar 11, 2011 | ViewSonic E70f 17" CRT Monitor
Blank Space Around Screen
Reduce the resolution a little.
Sep 20, 2017 | Acer H233H bmid Monitor
Geforce 3 analog output: I have horizontal, blurred/faint lines scrolling from bottom to top of display, spaced 6 inches apart.
what kind of monitor? Have you replaced the cable? Try the pc on another monitor. You need to see if it's actually the monitor or the video card. replace the broken or defective part.
May 30, 2009 | Nvidia 64MB GeForce3 AGP Video Card with...
My screen is stretched with a 1 and ahalf inch black space on the top and bottom
Most LCD monitors have a couple of control buttons at the top or on the side. Inside the menu, there should be an option called "Auto Adjust" which senses the input signal and resolution, and then shifts the monitor to match it. Have you tried to auto-adjust the screen? There may even be a button called "Auto" on the monitor.
May 13, 2009 | Computers & Internet
Picture tube has a six inch blank space at top of tube
Do you Have a pip option on the tv or remote. pip stands for picture in picture. check the remote to see if theres a pip button if so try clicking it
Nov 24, 2008 | Televison & Video
Vertical section problem
I have found an fix for this a capacitor 2494 needs to replaced.
Aug 21, 2008 | Philips 27MT3305 27" TV
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
White lines
These are retrace lines. This may be a fault in the blanking circuits. On some occasions a weak CRT can also cause blanking lines to show.
This is something you would not be able to service yourself. I would suggest to have an estimate done on the TV set for you to decide if it should be serviced or not.
Jerry G.
Apr 07, 2008 | Philips Magnavox 27MS343S 27" TV
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
98 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
