Question about Kirby Ultimate G Bagged Upright Vacuum
Upholstry mytstery I am trying to use the upholstrey attatchment on my ultimate g series, and after it is hooked up, it will not allow the vacuum to start. What am I missing?
There are two saftey switches. one on the air input, and one on the air output. someting has to be covering each. USE the SAFTEY CUP on the input and the Hose on the OUTPUT. does that answer your questions 4n4l <unt?
Posted on Aug 02, 2008
Kirby ultimste g series green light?
that means its working properly. If you have no suction then it is usually the belt and or the bag. so make sure your bag is not full , make sure everything is attatched properly and the green light is on.... The Kirby is the best vac out there and little suction should never be a issue for us.. I am a proud owner of the sentria..Love it..
Jan 21, 2013 | Kirby Ultimate G Bagged Upright Vacuum
What does my G2001 Kirby Apolsltry cleaning tool look like?
Here is a pic of what you want.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=G2001+Kirby+upholstry+tool&rh=i%3Aaps%2Ck%3AG2001+Kirby+upholstry+tool
Mar 20, 2012 | Kirby Ultimate G Bagged Upright Vacuum
How do you attach the upholstry attachment to your hoover steamvac
The hose hooks into the dirt bucket on the front where a clear plastic block sets. Put the hose in that slot and then hook the tube for the water at the top of the hood.
Nov 27, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Won't **** the water back up, what is wrong?
Either the height adjustment isn't on the lowest setting or the belt isn't on properly so that the brushroll will spin. Here is a guide to tell you how to properly get the belt connected. It is written for the main power nozzle, but should give you the basics because the shampooer head works the same way as far as the belt hook-up is concerned...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps,
Marci
Mar 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Hoover steam carpet and upholstry cleaner
I have a model F6211. On mine you have to remove the hose caddy and the door is under it.
Hope it helps.
Oct 11, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Shampoo attachment
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic cup with two hooks on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier. Now, put the shampoo gun on the end of the hose and you're ready to go.
Instruction manuals available in DVD, VHS or book format by following this link,..
http://stores.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_KIRBY-OWNERS-MANUALS_W0QQcolZ4QQdirZ1QQfsubZ7656839QQftidZ2QQtZkm
Hope this helps...
Aug 09, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Do not not how to use the shampoo cleaner on the kirby diamond edition /the ultimate g series
i ordered the manuel online for less than 10.00 and was there at my house in 2 days it was everything i needed..full of attatchement instructions.. i ordered from Kirby..
Jul 05, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Upholstry set up for ultimate g kirby.
Remove the entire cloth bag assembly and put the hose on the side where the bag came from. Remove the power nozzle and put the intake guard onto the front. (this is in your attachment set...the only one with little hooks that sit on the bar in front) You can change from the long handle to the short if you'd like also. You get the handles off by pushing the "seatbelt button" located at the rear bottom of the handle and pulling the handle straight up and out. Now, put your spray gun on the hose. Don't forget the little suds nozzle that goes on the end of the spray gun. I like to use a half and half solution of Kirby shampoo and water in the gun. It makes a nice dry foam that only wets the surface of the furniture. If you use more water, it takes longer to dry.
If you need a manual (book or DVD) for your Kirby, try this link....
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope I helped...
Marci
Mar 11, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Upholstry attachment
Check to make sure that the hose hasn't cracked, where it hooks up near the motor. If so, replace the hose.
Nov 11, 2007 | Hoover F5906-900 Upright Steam Vacuum
Kirby Ultimate G Series
Ok, I will try to explain this as well as I can. Please bear with me. Remove the dust bag, cover and all, from the machine. Attatch the shampoo tank to the part where the dust bag attatched on the machine (not on the handle). Remove all attatchments from the front of the machine, and attatch the shampoo foam "collector", ensuring that the belt is over the drive. Connect the small hose between the tank and the foam collector. Mix the water and shampoo as directed on the bottle, in the tank. Turn the knob on the top of the tank to on, then start the machine. I run the foam over about three sections, and then turn the knob back to off, lower the collector, and run back over it to pick up all the foam and dirt. I hope some of that makes sense.
Apr 12, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
