Question about Whirlpool LSR5132PQ Top Load Washer
Spin on whirlpool LSR5132PQ washer
My washer wont spin, it makes all the right sounds like its supposed to but it wont spin the clothes out. I need to know what I can check or change to fix the problem
    Novelist:
  • 116 Answers
Bases on a generic whirlpool top load...
There is a coupler between the motor and the transmission.When it starts to wear it will exhibit an intermittent spin and ultimately will stop altogether.
First unplug your machine.
Behind the top control panel near where it meets the top of the machine there is a philips (cross) screw on either side near the edge. Loosen this screw on either side and the control panel will slide slightly forward the flip up and back.
Under the control panel on either side is a large gold or silver spring clip. Insert a large screwdriver on the downward hook end on the lid side of the clip and lever the screwdriver backwards. this will unhook the spring clip and it can be removed. there will also be a 3 prong power connection under the control panel on the top panel that needs to be disconnected. Some machines have a large wiring coupler that should also be disconnected.
With both clips removed you will need to stand in front of the machine. If you grip just inside of the opening in the top, the whole cabinet will tilt forward to about a 45 degree angle and pulled completely away from the machine.
With the cover off you can see the white (or off white) pump in the middle at front lower portion of the machine. There are 2 spring clips which attach the pump to the motor (do not disconnect the hoses). These clips spring out of the way with a gentle levering of a screwdriver. Pull the pump slightly forward then tuck it off to the side.
You will now see the motor. There will be 2 spring clips that hold this motor to the frame. There may be 2 screws securing the clips onto the motor, remove these and gently lever the spring clips off. The motor should fall away from the frame.
The motor coupler consists of 3 parts One part attaches to the motor shaft and is white in colour there will be a rubber disk and another white part attached to the transmission shaft. This entire coupler assembly will have to be replaced(all 3 parts). The white parts can be pried off with a screwdriver.
Reassembly is the reverse of the disassembly.
Posted on Jul 29, 2008
Whirlpool washer ties clothes in knots on spin cycle
Its the wash or rinse cycle that is tieing the clothes in knots not the spin cycle. Try putting less shirts in. It happens because of the agitation during the wash. Or pin the sleeves together.
Mar 09, 2015 | Whirlpool LSR5132PQ Top Load Washer
Why does my Whirlpool washer LXR 7133JQ1 washer not spin the water out of my clothes like it should?
Is the high spin function set? Are you putting too heavy of a load in.. ? The more clothes you put in, the wetter they'll be when done.
Mar 12, 2010 | Whirlpool LSR5132PQ Top Load Washer
Washer wont work at the spin cycle phase
you nead to replace tjhe door switch.the part#for the door switch is 8318084.
Nov 14, 2009 | Whirlpool LSR5132PQ Top Load Washer
Maytag washer wont agitate
Well if it does it in all cycles you can rule out the timer. I would say the agitator is maybe striped out.
Jun 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
The inner tup on my whirlpool washer is loose.
look at this part at www.repairclinic.com/SSPartDetail.aspx?=t-LSR5132PQ-%3d%3di541811&PartID=541811 This is a washer's lint catcher and when clogged will prevent complete water removal. As far as the unbalanced check the levelness of your machine in both directions.
Mar 10, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer doesn't spin.
Hi, sounds like you need a motor coupler.
Dec 28, 2008 | Whirlpool LSR5132PQ Top Load Washer
Washer won't spin unless you lift lid. LSR5132PQ
You need the lid switch adjusted or replaced. Easy and inexpensive. With the correct model # I can get you schematic and part #s. Dave www.washermd.com
Dec 13, 2008 | Whirlpool LSR5132PQ Top Load Washer
Washer will not dash during use after clothes are added
Check to make sure your agitator is working. The agitator comes in 2 sections, a top (#3) and a bottom (#4). Spin the top section clockwise and than the opposite direction. It should spin free from the bottom section in one direction but when turned the opposite direction it should spin the bottom with it. Hopefully that makes sense. If it doesnt, you need to replace the agitator dogs (#10). Very simple to do. the part # is 80040 and theyre about 8.00. Hope that helps. Let me know if you need help with the install or the par itself. dave www.washermd.com
Oct 23, 2008 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal De
