Is the water on? Does the pump run when emptying machine? If yes to both, try running the machine through a spin cycle if you can and let it finish on its own. The valve should close and allow it to fill. Also, top or front load washer? ... These may help
How to Fix Washing Machine That Won Fill With Water DoItYourself com
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Hello John, The most probable reason the washer is not filling is because of a blown fuse that is part of the lid switch asm. By UNPLUGGING THE WASHER and removing the 2 INNER screws on the the control panel and the control panel can be rotated down to see the fuse in the lid switch asm. Here is where the fuse is on the switch asm. its circled in red
Make sure your cold water tape is turned on and the screen in the water valve is not plugged up, it may be trying to fill with cold water and cant get any, try filling the washer with cold water on a "wash" cycle to confirm it it fills with "cold" then just the rince cycle ion the timer may be faulty and would need to be replaced
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
