Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Dead KDLW40A12U I have the above tv that is totally dead, No responce? Any help is greatly appreciated.
  • iceman-otzi Aug 04, 2008
    I have the same problem turn on TV green light for about 5 seconds then flashing red light for seven flashes. The only thing I can think of is the power cut the same day!!! surge problem I suspect! Oh no £££££££££ss help…
    Novelist:
  • 135 Answers
The TV develops a low voltage which a simple microprocessor uses to turn the power supply on when you use the remote or TV power button. Sometimes sets will show a red power light when the TV is in stand-by mode which turns green when it turns on. If you don't have that and don't hear a click when you first plug in the TV, you probably have a power supply problem. If you had a power surge, it could have blown the AC fuse. Try replacing it with the exact same rated fuse and you might get lucky. If it blows again, it will need service.
Posted on Nov 11, 2008
Tv dead, not coming on, help
hi do you mean totally dead, if so the fuse inside could have blown thanks
shaun
Jun 14, 2017 | Televison & Video
1971 monte carlo
It the battery is dead the next day it has to be a short on a wire that is always hot.
Feb 17, 2014 | Cars & Trucks
Completely dead laptop.
sometimes you just need to remove the battery then power-up the unit using its charger.
Jul 05, 2013 | Toshiba satellite c660
Lcd tv totally dead
Follow the money or the voltage here- standby power appears to be up but if so why no standby light up front? Have you checked all the caps in the supply? The 5 volts should be for the micro so this sounds like either main supply/standby not up or something pulling it down..
The real clue here is set has no power indication of standby---you are aware of the reason the caps fail in the standby power supply?
Just trying to get an idea of how much expertise you have.
Mar 30, 2012 | Samsung LN32C540 32 in. LCD TV
Broke down engine backfired and stopped doing about 25 tried to restart but NO responce frome the starter botton.whiles waiting for AA tried again and it started tested most things but running poor at lo...
Check battery for a full charge. Put on charger and bring to full charge. Put load tester on the battery, checking for weak or dead cell. Check charging system to ensure it is working properly.
Apr 15, 2011 | Triumph Bonneville Motorcycles
What is the battery life expectancy for the 2006 Buick Lucerne?
Battery life is a very complicated issue, there are TONS of factors. High temperature kills batteries, if the fluid goes low, that kills batteries. If you forget and leave lights on, and the battery goes totally dead, (totally dead, zippo, not anything) that kills batteries.
Alternator diodes that fail kills batteries. So 4 to 8 years is typical life IN ABSENCE of the above types of issues. My favorite battery is Interstate. They just work really well. Costco has great battery prices, bumpy for service... Really Dislike Sears die easy.
Oct 19, 2010 | 2006 Buick Lucerne
I have a dead hard drive 2.5" SATA
If it is truly dead and you MUST have the information from it then the only real alternative is to send it to a data recovery expert. These services are NOT cheap
If it clicks or makes random noises clicks pings etc then it is most likely dead I am afraid.
Jul 19, 2009 | Coolmax CD-350-COMBO (CD350COMBO) Infrared...
Dead NV-SD225EU
This F04 code means that the cassete carriage has been pushed out of alignment due to the toys being inserted into the machine. It may have lost total power due to a safety component eg a fuse blowing. This would need a service repair person to fix it as the cassette carriage may also have got damaged and would need repaired as well as the carriage alignment having to be re-timed.
Mar 26, 2009 | Panasonic Televison & Video
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
168 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
