Question about Dell A960 All-In-One InkJet Printer
Fax name can you tell me how to change the name on my fax settings I can't find the backspace button
    President:
  • 2,351 Answers
Hi c_mcnair, when you install the software for you're A960 printer it also installed the Dell All-In-One Center. Within in the dell center you can change you're fax settings. To open the dell center do this, Click Start → All Programs → Dell Printers → Dell AIO Printer A960 → Dell All-In-One Center. Once opened click fax setup utility. Fax starting on page 40 in manual. Once in the fax setup utility you'll be able to change any & all fax settings. I do not have the software installed. If I did I could be more specific, step by step.
(You can't find the back space button). If this refers to you're keyboard it's just above the enter key. It's the key with the arrow pointing to the left on it. ( <------ ).
If you no longer have the user manual for you're Dell A960 you can download it by clicking on this link.
http://support.dell.com/support/edocs/systems/a960/en/a960en.pdf
You'll need Adobe reader software to read the .pdf file, AKA manual. You can download it for free.
Click this link for Adobe reader.
http://www.download.com/Adobe-Reader/3000-2378_4-10000062.html?hhTest=1
Good luck c_mcnair!
Mike
Posted on Jul 30, 2008
We have a Canon 810 Fax Machine. How can we change the fax header?
change unit name
press additional functions button
then use the arrow - + buttons to select
tx/rx settings press ok
tx/rx common set.
tx settings
unit name
http://downloads.canon.com/cpr/pdf/Manuals/lc_800_series_basic_operation_guide.pdf
page 333 or section 12
Oct 28, 2016 | Canon Laser Class 810 Plain Paper Fax
How do I change Name of sender?
1. Press: function, 3,#, #
Display shows: your own number
2. Press: start
3. Enter your fax number (max. of 20 digits)
by pressing the number keys.
• To insert a space between digits, press
the # key. To enter "+", press the * key.
• If you make a mistake, press the SPEED
DIAL key to backspace and clear the mistake.
4. Press: start
5. Enter your name by pressing the appropriate
number keys as shown below.
• To enter two letters in succession that
require the same key, press the
SPEAKER key after entering the first letter
• To change case, press the REDIAL key.
Press # or * to scroll through symbols
and special characters.
6.When finished, press: START
STOP
Dec 06, 2012 | Sharp UX 60 Fax
This fax machine was donated to our school and we need to change the banner message that appears at the top of page when something is faxed.
Presss the Function button and then data registration button ,under settings you will find Tel number set your number.The next funcktion is user name, set your user name and press set.
Dec 14, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
I am want to change the name on my fax machine how do i do that?
hit the "menu" button, scroll to "general set up", scroll down to station ID and thats where you set your fax number and name info.
Oct 27, 2009 | Brother IntelliFax-2820 Laser Fax
How do I change the settings. (Phone #, Buisness name?)
Press the function -dataregistration button select dataregistration press set or start. User settings will be displayed press set user name will be displayed and press set.Change user name.For phone number,if user name is displayed,scroll with arrows untill Tel number is displayed.
Oct 13, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
How can i chanche de fax number dat is printed. That number is not good, i wil chanche this
you need to go into the menu and look for settings fax the n look for the fax ID here you can change the number and the header the header is the name you want printed on top of the page ie your company name.. you can find the sections by looking on the right hand side of the display and you should see a button called reports here you can print off the section rep[ort which tells you where to find the settings in teh menu
Sep 29, 2009 | Canon FAX-L350 Plain Paper Laser
Please tell me how to program the fax presets...thanks.
By pressing the menu button,button is located left of LCD display.Scroll to usersettings.Press ok.Under usersettings you can change the terminal id,volume telline settings,user name and tel.
Sep 23, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Sharp AR-275 copier with fax module. Need to edit sender ID
push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Mar 04, 2009 | Sharp AR-275 Copier
Name on paper
Depending on the machine, the setting will be in one of two locations, In your menus under either Machine Settings or Fax Settings. You will find the machine ID, That is where you change it.
Mar 13, 2008 | Canon FAX-L900 Plain Paper Laser
Fax number
Press fuction 7 1 key in date & time press set
May 22, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
Dell A960 All-In-One InkJet Printer Logo
107 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
