JVC ¾? Umatic Model CR-6060U parts or alturnative
JVC ¾” Umatic Video Cassette Recorder Model CR-6060U
A repair guy said the "video heads" need to be replaced. (seems to be
unavailable) He said it was a unit which included transport parts. The
problem is no play, FF, after I cleaned belts and hubs underneath unit the
RR worked. I can see while trying to open up the top, a roller and hub
are, tarred ( black residue on hub and eroded roller.) Two side panels
seem to flip up after removing all visible retaining screws, however there
was strong resistance and I did not want to stress or brake anything. If I
can get the side panels open then I can remove everything in the way and
at least clean the roller and hub. All suggestions on finding "video
heads" part or other possible solutions would be a big help. Thanks.
Thanks for your info. As it turned out there was no parts and I returned it to the seller and called it a day.
Posted on Aug 22, 2008
I used to repair these units and still own one. Each
one of the black side panels (control panel covers) is
held in place by four screws. After removing the
screws and control knobs, the right panel should come
right up. You may need to move the left hand panel
forward to clear the headphone jack before it can be
removed. From your description, it sounds like the
FF/play rubber tire is worn. After removing both side
panels, remove the cassette elevator. The elevator is
held in place by four screws. Two on each side of the
elevator. Pull the unit up, the FF/play and RR rubber
tires should now be clearly visable. Have you found a
video head yet?
Posted on Aug 16, 2008
CLASSIC RCA AUTOSHOT VHS CAMCORDER.(DSP3) PROBLEMS
The vhs camcorder has very complex mechanics and hold many traps for the inexperienced.
I suggest you begin by obtaining a standard vhs recorder and remove the cover to expose the interior and then study it. You will find the engineering and interior geography of your camcorder similar.
The round shiny barrel-shaped thing contains the record and playback video heads and the sound head is separate and looks like a larger version of what can be seen in a standard audio cassette recorder.
The interior must be extremely clean, the drive belts in good condition and the clutches and rubber rollers also in good order.
Nov 16, 2017 | RCA CC6151 Camcorder
Jvc video recorder. cassette will not eject
make a hard reset and try to eject
Jul 08, 2008 | Cameras
I need the video head for a sony slv 815
The parts you are looking won't be easy to find, go online to sony, contact customer support, and the technical department to see if they can help, if not! try and find a repairman that still repairs vcr's, because he would have access to part suppliers that may still carry what you need.
Apr 21, 2012 | Sony SLV-N81 SLV-N81 Video Cassette...
I have a JVC, DVD recorder/video cassette recorder, model DR-MV7SU. When I try to rewind the tape, it will stop and try to eject the cassette, the tape gets commingled inside, What can I do or what website...
Hello
Check all the belts in the vcr mechanism. Replace them all at one time. You can get it is kit form, from most of the electronc spare part shops at your town. Give them the model number of your device. They will select it for you. The fault is with elongated driving belts. OK.
Jun 29, 2011 | JVC Televison & Video
JVC CR-6060U Stuck in 'Search' mode
TAKE IT APART CHECK TO SEE IF ANYTHING IS STUCK,,TRY A JUNK TAPE ,,,,BLOW OUT ANY DUST ,,USE A HEAD CLEANER WITH ALCOHOL
Feb 06, 2009 | Samsung VR8460 VHS/S-VHS playback VCR
Lines on my JVC mini dv recorder
Please use Mini DV Video head cleaning cassette as it seems video head is dirty / clogged in camera.
Oct 24, 2008 | JVC GR-D295U Mini DV Digital Camcorder
Vcr will not load vcr cartridge
The tape mechanism is not loading and/or driving the VCR tape properly. Most people don't realize that the tape is physically pulled out of the VCR cassette and wrapped around the video heads in a semi-circle configuration. Your VCR guides are pulling the tape out but not retracting it into the cassette shell when you press eject. Causes: mode switch, mechanical failure, video head speed/drive problems. All these problems are somewhat complex for a novice repair person and don't forget that new VCR's are selling for $30 at the big box stores....Glen.
Jun 05, 2008 | JVC DR-MV1S DVD Recorder/VCR
Sanyo DVD Player & Video Cassette Recorder - DVD-7200
dvd does not play but video cassette does...fixable???????
Apr 16, 2008 | Sanyo DVW-7200 DVD/VCR
DVD player /video cassette recorder
pull your head out of you *** and clean the heads
Dec 14, 2007 | Televison & Video
Jvc gr-dv500u
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 27, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Electro Med Services...
