Went away for a week plasma turned off at mains came back turned tv on it normally gives 3 clicks then comes on but it only gives 2 clicks,power is going to the tv as it gets hot you can see it light up alittle but no picture,its a wharfdale plasma 42 inch model no w42h40pe,do y know what the problem could be
    Sergeant:
  • 260 Answers
The problem is going to be internal and i would recommend a repair serivce.
Potential causes for the problem are:
  • Turning the main power on while the tv is plugged into the outlet.
  • A power surge or dip
  • The tv being bumped or dropped
  • the tv being exposed to warm or cold temperatures.
Posted on Jul 29, 2008
My 50 inch phillips plasma made a loud pop and the picture and sound went away. if i plug it in it makes the normal click a few times and the green light comes on and then flashes red.
I have the same problem. after pulling the back off. we found that the 3 capaciters above the 2 power relay switches are bad. i am currently looking for a scematic so i can replace the 2 dios that burned up due to the issue along with the capasitors.
Dec 08, 2010 | Philips 50PFP5332D 50 in. Plasma...
JVC PD35D30 Plasma won't turn on anymore...
Yeah, I was going to suggest power supply issue. Plasmas IMHO, are not worth spending the money to fix. Its the reason why they are so cheap these days in comparison to LCD's. I had a 50" Samsung Plasma that went out on me within 2 years (E Buffer board and XMain problem). Its not about the manufacturer but more about the Plasma technology. Do a few searches about plasma and you will find a lot of problems with these tv's. Id say cut your losses, sell the TV for parts and buy a more reliable technology
Jun 07, 2010 | JVC PD-42WV74 42 in. Plasma EDTV
Panasonic plasma tv doesn't turn on, red light flickers twice
hi look for any swollen capacitors, also plasma's do suffer from poor solder joints on the power board, so check for any rings around the solder pads, test the voltages on the white connectors with a meter the voltages will be written along the connector,thanks
shaun
Mar 01, 2017 | Panasonic Viera TH-50PZ85U Plasma TV
The menu screen will not go away!
Try to push the menu button on the tv itself numerous times and see if it will go away (since the buttons are not used often they become resistive and it could be any button,if that dont fix it then the main digital board is bad.
Mar 19, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
My plasma tv go's to standby while I'm watching it
I have the service manual and it has a lot of symptoms for your problem can you tell me exactly what happens when you first start the TV but it sounds like a scan converter problem This is what I got from the service manual page 4
4-2. Self Diagnosis Function
4-2-2. Criteria for Judgment of Abnormality
11. Detection of abnormality in communication with scan
converter.
(Name of this function on the service menu : OTHERS)
Warning when communication with scan converter
cannot be performed normally
or this could be it
14. Detection of PDP failure.
(Name of this function on the service menu : Nil)
PDP is suspected to be defective when DIGITAL 5 V
is normal among the voltages (VS, VA, DIGITAL 5
V) required to drive PDP while both VS and VA are
not inputted.
When all the following conditions are satisfied, the
machine enters once to the STANDBY mode then turn
the main power back on again.
1) DC 180 V power is 40 V or less.
2) DC 70 V power is 20 V or less.
3) DIGITAL 5 V is normal.
The above-described operation is repeated three times.
If the above three conditions are still satisfied, the PDP
is judged to be faulty and the main power is shut
down.
I can send you the manual if you want it
Sep 20, 2009 | Sony PFM-42V1 42 in. HD-Ready Plasma...
PIONEER PDP-424MV Plasma TV
I have the same TV, well, nearly, PDP434.
The only part I ever sell for these is the main PSU (power supply).
The TV "checks" it self using a self diagnostic system. As soon as it discovers a problem, it shuts down and blinks an error code on the front LED.
It always seems to be the PSU.
I hope this helps at least a bit.
Mar 28, 2009 | Pioneer PureVision PDP-424MV 42 in. Plasma...
No power to toshiba plasma tv
This answer is for sjmhan: It sounds like you have a fault on the power supply board of the tv. Please before you open up your tv find out how to take basic precautions against electrical shock and how to discharge capacitors safely. First check if there is a glass fuse inside of the set and if it has blown replace it with one of the same rating. If you replace the fuse and it blows straight away or it still does not come on then it could be quite a few things. Either a faulty resistor or diode or voltage regulator or even the mains transformer itself. One word of warning: NEVER toucch any of the pins of the transformer as this cannot be tested directly without specialist equipment. If you find that it all is too complicated for you then dont feel like you have failed just re-assemble it and find a competant technician. Good luck.
Kimlong: I think you have a faulty component on the power supply board most likely a faulty diode. If you can check this for yourself otherwise find a competant technician. Hope this helps.
Sep 01, 2008 | Toshiba 50HP66 50 in. Plasma Television
No screen display - VIzio 50" Flat screen TV
If you purchased the TV 6 months ago, still under manufacturers warranty. They normally give customers 1 year warranty coverage.
It looks like the main board will have to be replace on this TV or fix to the component level.
Mar 21, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Unit will not turn on from standby
I had a similar problem and it was caused by my cable box being in scart 1 as soon as I changed over to scart 2 the problems went away,
Nov 04, 2007 | Hitachi 42HDS69 42 in. Plasma Television
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
