Question about Whirlpool Washing Machines
Sometimes it spins out,but not well,cloths too wet. Top load,beltless,about seven years old.
    Novelist:
  • 116 Answers
Bases on a generic whirlpool top load...
There is a coupler between the motor and the transmission.When it starts to wear it will exhibit an intermittent spin and ultimately will stop altogether.
First unplug your machine.
Behind the top control panel near where it meets the top of the machine there is a philips (cross) screw on either side near the edge. Loosen this screw on either side and the control panel will slide slightly forward the flip up and back.
Under the control panel on either side is a large gold or silver spring clip. Insert a large screwdriver on the downward hook end on the lid side of the clip and lever the screwdriver backwards. this will unhook the spring clip and it can be removed. there will also be a 3 prong power connection under the control panel on the top panel that needs to be disconnected. Some machines have a large wiring coupler that should also be disconnected.
With both clips removed you will need to stand in front of the machine. If you grip just inside of the opening in the top, the whole cabinet will tilt forward to about a 45 degree angle and pulled completely away from the machine.
With the cover off you can see the white (or off white) pump in the middle at front lower portion of the machine. There are 2 spring clips which attach the pump to the motor (do not disconnect the hoses). These clips spring out of the way with a gentle levering of a screwdriver. Pull the pump slightly forward then tuck it off to the side.
You will now see the motor. There will be 2 spring clips that hold this motor to the frame. There may be 2 screws securing the clips onto the motor, remove these and gently lever the spring clips off. The motor should fall away from the frame.
The motor coupler consists of 3 parts One part attaches to the motor shaft and is white in colour there will be a rubber disk and another white part attached to the transmission shaft. This entire coupler assembly will have to be replaced(all 3 parts). The white parts can be pried off with a screwdriver.
Reassembly is the reverse of the disassembly.
Posted on Jul 29, 2008
We have a top loading washer that is two years
that could well be the programer playing you up or the motor not working right,,none of them are a cheep fix,,, sorry!
Jun 13, 2010 | Washing Machines
After spin cycle is complete, clothes in washer are still too wet
Check for obstructions in the pump and discharge hose. Check the motor coupler. Here is a video that should help.
http://appliancehelponline.com/topdirectdrivevideo.html
Jun 04, 2010 | Kenmore 22422 Top Load Washer
Clothes too wet after spin cycle
could be the clutch slipping not releasing the brake allowing it to get upto full speed
Feb 28, 2010 | Kenmore Washing Machines
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Aug 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
Spin cycle problem
hi this is the part you need to replace motor drive coupling located on the motor and the transmission. replace this part $25.oo thanks the appliance doc
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
