Question about Goldstar MV-1615 Microwave Oven
Microwave keypad is locked
My microwave keypad is locked. I can see the time, but when I push a button it says the it is locked. How do I unlock the microwave?
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
Touch and hold START more
than 4 seconds. "L" will
disappear and you hear two
beeps. At this time the oven is
ready.
Posted on Aug 23, 2008
Ge microwave model JNM7196dk1bb is locked 1 cant unlock with cancel button
Try this,
Press and hold the "Clear/Off" button on your microwave oven's keypad for about three seconds.
Wait for the "L," which indicates the microwave is locked, to disappear from the display.
Open the microwave using the open latch button.
Nov 05, 2017 | GE Microwave Ovens
My microwwave is not heating,
Hello
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol (like the "Start" button in the photograph).
Oct 05, 2011 | Sanyo Microwave Microwave Oven
Model 565.60512000 manufactured 3/2000. there is a L besides the time. I have lost the manual so do not know how to unlock. Instead of seeming locked, I can enter cook time but then the microwave turns...
HELLO.
The problem with your microwave's touch pad needs some simple troubleshooting steps to rectify the problem.
1 Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
2 Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
3 Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
4 Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
5 Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
Reach me for further assist.
Thanks.
Sep 06, 2011 | Kenmore 63652 Microwave Oven
Microwave is locked up. Says Lock on screen and cannot get it to go away after hitting Clear several times. How do I get it off "lock" status?
HELLO.
GE manufactures various models of microwaves with a range of features.
Among them is a child safety feature that allows parents to lock the keypad. Though children can still open the door, the keypad lock prevents them from starting the microwave. The lock is in the form of a keypad code that renders the buttons inactive.
* 1 Press and hold the "Clear/Off" button on the microwave's keypad.
* 2 Hold the button down for three seconds.
* 3 Wait for the "L" on the keypad's display to disappear and display the time instead, signifying that the device is no longer locked.
Willing to help solve more problem.
Thanks.
Aug 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My Jenn-aire microwave says locked and has a picture of a padlock. I was microwaving bacon and had just put it some to cook ( my second batch per se) and everything was locked up. I tried pushing options...
Most likely you set a child lock (front panel lock) by holding a button too long (3 seconds). Without a model number, I can't be absolutely sure of the keypad lock for your Jenn-Aire microwave. Usually, the key will have a small padlock icon on it. Press and hold this key. On my microwave you press and hold Start to toggle the lock off.
On a Jenn-Aire JMW2430 and similar models, the Button Lock is activated by a several step process (More and Button Lock). However, pressing and holding the Start button will deactivate it.
I hope this helps.
Apr 19, 2011 | Jenn-Air Microwave Ovens
PLATE NOT ROTATING AND THE KEYS NOT FUNCTIONING
If keypad is locked, hold down clear button for 3 seconds to unlock keypad.
May 12, 2010 | GE JVM1542 Microwave Oven
Bosch HES435U - Stove Keypad is Locked
Locking or Unlocking the oven control panel
1. Access Select Function Menu
2. Turn knob clockwise until Lock Keys is flashing
3.Touch Start. Key Pad locked is displayed.
4. To unlock keypads, touch cooking mode and hold for 5 seconds. Display will read unlocking key pad
5. When unlocked the clock will again appear in the display.
Apr 29, 2008 | Bosch HLK4525GB Convection/Microwave Oven
Setting clock on Amana Microwave Mod#FBG623T
It may possibly be locked, in which case holding the enter/start pad for over 3 seconds may unlock it.
Otherwise, you may want to call Maytag / Amana at:
1-800-688-9900 U.S.A
1-800-688-2002 Canada
Nov 04, 2007 | Bosch HMB402 Microwave Oven
Wont work...
check control circuit and door switches,
Oct 27, 2007 | Emerson Black Microwave Oven
Can't use the microwave
To lock or unlock the keypad, press and hold the CLEAR pad for 5 seconds. If this recurs, you may have a power line problem or trouble with your controller. If you suspect trouble and it's under warranty, don't hesitate to contatc GE via ge.com. If you don't have your mower's manual, you can download one at: http://www.geappliances.com/service_and_support/literature/
Nov 07, 2006 | GE Advantium 120 Convection/Microwave Oven
Goldstar MV-1615 Microwave Oven Logo
342 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
