Need channels reset
27ax1b I don't have the remote and only a few channels are showing. I need channel 3 to work to hook this up to my cable. How do I reset the channels???
    Sergeant:
  • 260 Answers
If you do not have a replacement remote and their is no menu button on the tv then you will have to do a hard reset.
To do this you will have to unplug your tv and all connecting components until such time that the tv is reset. You will know it is reset when the tv asks you when you turn it on to run a channel program.
Good luck.
CH
Posted on Jul 29, 2008
Have a used Emerson tc1375a hooked up to cable only gets channel 3 and 4 picture is great. Does it need to be reset or what can I do
Usually a TV must be set to either channel 3 or 4 to receive a TV service provider such as cable or Direct TV. The service provider now controls your channels and broadcasts on either channel 3 or 4. You choose channels from what ever equipment they gave you which is usually not the remote that came with your set. You may need to check the way you are set up. If you are using an antenna go into the menu on the TV and make sure it is set to antennae not cable. This may also be the problem. Good luck.
Feb 19, 2015 | Emerson Televison & Video
I accidently pressed the channel button on my remote instead of the volume button. I now have no picture or sound. I tried returning to the previous channel but it keeps saying " channel not...
Not familiar with your model, but the problem sounds generic. I am guessing your set is hooked to a cable tv box, and that is where you need to change channels. I also guess that when you changed channels on your TV you probably moved from channel 3 to either channel 2 or 4 and the cable tv box is not sending to those channels so you lose picture and sound. Now, more guessing, you try to put the channel back to 3 on your TV, but still nothing happens. OK, if close so far, there are a couple of things to try. First, be really sure you are actually going back to the same channel you started with. Assuming you don't actually have the signal coming in on an auxiliary line-in and that you had it coming in on a channel, you may need to reset the presets on the television so that it recognizes the one important channel the cable tv box is sending out -- just follow your television menu to select or set channels. There is one more possible easy problem ... I have seen this one happen, after getting the channel correct and reset, if it still doesn't work, you mght need to turn the set off and wait one minute, then turn it back on WHILE the cable box is ON. This can cause the set to RE-Latch onto the cable box signal. It really doesn't sound like something is truly broken or needs replacement, sounds more like a user error. If your set is still under warranty, just call the Panasonic hotline (find it in Google, and they may be able to walk you through exact instructions for your model). Hope this helps.
Aug 29, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Can't get "no signal" off
Hey cthaemar, it sounds like it may have been switched off the correct channel. If it is hooked up with a Coaxial cable it will be on channel 3 or 4, and if it is hooked up with an AV cable then it would be on one of the inputs.
If it's channel 3 or 4 try pressing the gray TV button on the remote and changing the channel. If that doesn't work you may need to use the TV's remote or the TV itself.
If it's on an input press the same gray TV button and then try pressing Input. With this you can also try the TV remote or the TV itself to change those if our remote doesn't change it.
Let me know if you have any other questions or concerns!
Tommy Faust
DISH Network
Jul 12, 2011 | DISH Network 322 DTV Receiver
How do you scan the channels on the PDH42L40? I need to go to a certain channel on the TV to get my Dish Network to work. It is not hooked directly into a box, it is on a secondary receiver. Please...
hello and good day to you!!!!
if you wish to scan your TV to go for a certain channels..
you need to reset auto scan on your TV...
this are the procedure on how to reset auto scan...
  1. Get your remote control..
  2. press the menu button on your remote
  3. go to the settings..
  4. try to find the auto search.
  5. after you find the auto search press enter to scan the channels.
Note: Please complete the 100% scan for better results..
Jul 12, 2011 | Televison & Video
I have a visco TV and I cannot get it off of channel 1. The remote does not work so I bought a universal remote but it still won't work. I tried to codes for NEC and Polariod as suggested by others,...
There should be channel buttons on the TV itself, try using those. Also, you may want to try changing the input from the Cable Box.
I am curious as to why the remotes don't work. Also, how did it get onto channel one. Did you get the TV used?
Here is a link to the AV Science Forum. It seems other people have challenges with this TV as well.
http://www.avsforum.com/avs-vb/showthread.php?t=745952
May 19, 2011 | Televison & Video
I received this tv from a friend. I just want to hook it up to by dvd player in my kids room but since there isn't a port for that I've installed a modulator through the cable hookup. Now I just need to...
do you have a remote for the tv . if not you can get a cheap one from walmart (GE or RCA) they are cheap and easy to program to your tv use it to enter menu
go to (screen or picture) using the up or down arrow change it from cable to tv
if that don't work try the input button on remote that is most likely to work to get you the channel you need to use the wii
Nov 02, 2010 | Televison & Video
I can't get channel 3 to show satellite channels. They only show up on Video 3. I need channel 3 to work for surround sound. I checked wiring diagram and it looks like everything is hooked up the way it...
Hi there Guest, what you will want to check is what type of cable is hooked up to the TV. To broadcast on channel 3 it needs to be connected from the receiver by a Coax cable instead of RCA/HDMI/Component cables.
Tommy Faust
DISH Network
May 15, 2010 | DISH Network IR Remote Control
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Channel issue
Do you have a lot loose connection inside tunner. Need be re solder. Do this and TV will be ready!!.
Apr 17, 2008 | RCA F27442 27" TV
Televison & Video Logo
431 people viewed this question
Top Televison & Video Experts
