Question about Thermador PG304BS Gas Kitchen Range
Oven light bulb
The light are not working. i remplace the light bulb with 10 w could not find the 5 w recomended but still have the same problem. Is it a fuse or something else?????
    Master:
  • 726 Answers
Yes there is a fuse inside the actal oven at the back you will have to take the cover off but i think the wire termanils might have come loose from the heat maybe
Posted on Jul 29, 2008
  • chris07551 Jul 29, 2008
    yes and could be the switch also
  • 4,472 Answers
It is possible it is the switch itself. You may want to try and find a 5w bulb. Check the socket with a multimeter.
Thanks,
Lee
Solenoides on my 01 Windstar need to be remplaced. So I did And Now the overdrive light is on all the time. What do I Do?
Go ovr ur work again..some wire or ground. Switch maybe tu. U can always take bulb out
May 22, 2015 | 2001 Ford Windstar
All three lights on my microwave ge model 1800 do not work. Is there a common fuse or something
suggest you go back to 10 amp globes and check that the fuse is good
Jan 01, 2015 | GE Microwave Ovens
I shorted out the counter lights on my frigidair microwave. The microwave works but not the lights. I've replaced the bulbs. What next?
The metal base may have fused together from electrical arcing when the old bulb was removed. The entire bulb receptacle (socket) will have to replaced. If you cannot do that yourself, the cost would be excessive. Just live without the light as long as the microwave gets the job done.
Dec 10, 2014 | Frigidaire FMV157GB Over-the-Range 1.5 Cu....
My light bulb went out in my dryer and I bought a regular replacement bulb from home depot and it doesn't work. Does my dryer need a special bulb?
Hello Eric;
My name is Peter. I am a retired field service appliance technician.
In general all appliances require a special bulb; your oven, refrigerator - the bulbs are designed for the service - extreme hot or extreme cold.
These bulbs are expensive.
Part Number 22002263 - 10 Watt - $11.00
Dec 07, 2014 | Whirlpool Dryers
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
BULB REPLACEMENT
that is just an 40w appliance bulb theres probably 10 diifferent manufactures that make this bulb and want allot for them u can find one at a local lighting store, or local appliance store,, this is a common bulb, to get to it u must remove the glass cover that covers the bulb. it should screw on to the receptacle.. hope this helps
Feb 05, 2010 | Jenn-Air JJW8230D Electric Double Oven
Fuse blowing on interior light/ remote
Was the bulb the same size and watt as the one you removed? Did you possibly cause a short in the fixture. I do not recomend using a larger fuse due to possible wiring dammage (risk of fire). Check the bulb for size and wattage/voltage check the holder to make sure it is not grounding out. Carefully check each step 2x.
Sep 20, 2009 | 2005 Volkswagen Passat
Microwave PLMVZ169 GCB night light push button does not work. Replace the light bulb. Push button still does not work. The work light does when I push the night light it stays on. Just wondering how to...
Q - While trying to change the light bulb on the oven, the bulb broke. When it did, it threw the circuit breaker and the whole oven went out. After resetting the breaker, everything on the oven works except there is no power to either light socket. Any ideas or suggestions on what to replace?
A - You tried to change the light bulbs with the power still on.....tsk tsk!!
Hate to say this....but probably blew out part of the circuit on the smart board ( the brains behind the key panel you touch ) when the short blew. The light relay on the smart board may have been damaged but 9 out of 10 times when I check them, the board itself is damaged.
check out this problem.
please do rate the solution.thank you for using fixya.keep updated.thanks,
May 03, 2009 | Microwave Ovens
Thermador PG304BS Gas Kitchen Range Logo
110 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
