Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore Model 587.1514* and cannot find the remaining portion of the Model number
I currently have a Kenmore Model 587.1514*, however, I cannot locate the complete model number on my dishwasher. The sticker that is on the door was apparently torn off by an over zealous kiddo trying to clean the kitchen. The door seal and the spray arm/tower assembly needs to be replaced, however, no body will even try to research the parts with the model number range above.
I need these two parts, and the dishwasher will work perfectly, however, I need some help on how I can find the complete model number and/or a location that will help me research the part myself. Are these two parts truely so different from other models in the 587.1514 range?
  • Anonymous Jul 30, 2008
    water remains in tub after washing
Those are all the numbers you need - the remaining numbers are just the color ie: 587.1514 is the model 587.15142400 means its white
Posted on Oct 25, 2012
catriver
  • 878 Answers
SOURCE: dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Posted on Nov 25, 2006
SOURCE: Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Posted on Feb 08, 2008
  • 188 Answers
SOURCE: Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Feb 20, 2009
SolutionGuy
  • 331 Answers
SOURCE: water won't come in
Cynthia,
There's a flood/safety switch in the dishwasher. It's there to monitor the water level. It does this by rising as the water rises... if it gets too high, it'll shut the water off.
Open the door and remove the lower rack. You'll see it right there in front. Lift and drop it several times to clear any debris. (In order for the dishwasher to get water, it has to be all the way down.) Now try your dishwasher.
SG
Posted on Mar 27, 2009
VtToolMan
  • 704 Answers
SOURCE: I need to know how to put the pump assembly back
Go to the link provided below and under the heading "Browse Subcomponents" click on the "Pump and Motor Parts" link. I think that shows what you're looking for. Otherwise, check the other diagram links for your model on the same page.
Hope this helps!
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=6651514590&pop=flush
Posted on Jul 28, 2009
Where is the thermal fuse located at on kenmore microwave model 665
Depending on the total part number 665xxxxxx a replaceable fuse is located behind the control panel usuallyon the floor of the control cabinet.
on one specific model "not yours" to check out the fuse locations a part number 309796 was found and I've included an image. Values of the fuses change based on specific models.
A typical location is included in the following image.
26047724-i5ybdsgcpm55v0g4hkv2rsri-5-2.jpg During previous repairs the fuse holder has failed and has required repair in addition to the fuse being replaced. This work needs to be accomplished by a qualified repair person. Even with power remove voltages remain because of stored engergy in the capacitors.
Hope this has been of help?
Jan 10, 2016 | Kenmore Microwave Ovens
Where can I locate the model number? It is no
Is the refrigerator a Kenmore? Some have model numbers located on the wall between the fresh food section door and the kick plate. Most have the model number around the fresh food compartment door frame Kenmore model numbers look like this=> 321.45678 I am here if you have questions or comments, Sea Breeze
Aug 21, 2013 | Kenmore Refrigerators
Where is the ignitor or thermal fuse of my kenmore elite Oasis Gas dyer Model 110.7705 located?
You listed an incomplete model but I think the second half of this pertains to your appliance:
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it heats, or you can use amultimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct.
May 17, 2012 | Kenmore Dryers
Kenmore model 106.53532300 side by side. Replaced compressor start kit, compressor now runs. Freezer freezes but refer still warm (60 degrees) what could be wrong
Are you cleaned the coils? Is it frosted?
If it is frosted then usually one of the defrost components has failed; maybe the defrost timer, defrost heater, or defrost thermostat.
Check it and keep us updated.
Jun 22, 2011 | Kenmore Side by Side Refrigerator
WERE IS MODEL NUMBER ON KEMNORE RANGE?
The model numbers on most Kenmore ranges will be located on a nameplate along the oven door, or lower drawer opening. Some models may have this information on the back of the operator console.
If this question is in reference to a microwave oven, the model number will be located along the oven door opening, or inside the oven cavity along the upper portion on either the left or right hand side.
If you need further assistance, please let me know. I hope this helps you.
Oct 06, 2010 | Kenmore Microwave Ovens
The Top portion of the Agitator won't spin.
This is a very simple fix, that's inexpensive and requires no special tools. It sounds like you need to replace your agitator dogs. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The dogs are part of the agitator cam assembly under the auger (top portion). These little plastic pieces do wear out with age, causing the slippage you are talking about. Replacements are available at appliancepartspros.com for about $5. For a little bit more, you can purchase the entire cam replacement kit (which includes the dogs, cam and seals) for around $11 or $12. Use your model number to begin your search criteria and locate these parts under the "Agitator Parts" section.
If you have questions, or require additional assistance, please let me know. I hope you find this information helpful.
Aug 19, 2009 | Washing Machines
KENMORE DRYER MODEL NUMBER 66912690 WONT HEAT
Check the voltage at the terminal block where the cord hooks up for 220 volts.
Remove the rear panel and check the thermal fuse located on the upper portion of the heat canister.
Check the Hi-limit thermostat on the bottom portion of the heat canister.
Check all the wires for a burned or loose wire.
Check continuity of the heating element.
Mar 08, 2009 | Kenmore 62602 Electric Dryer
Kenmore washer making noises while adjitating
could be worn agitator dogs try turning upper portion of agitator by hand and listen for slight rattle or motion in both directions if dogs are bad remove cap and center bolt pull upper part of agitator off dogs are in ceter of upper part ..part number 80040
Jun 09, 2008 | Kenmore Washing Machines
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
You are correct that the 363 means it was manufactured by GE.
You have to include the 363 in the model number when looking up parts. 3639619686
I just looked it up on sears.com and repairclinic.com.
You won't find it on GE, they don't list the models they built for other companies.
Post back if you have any questions.
Mike
Dec 30, 2007 | Refrigerators
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
320 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
