Cannot connect with SonicWall VPN Client with GigaFast EE420 R
I can connect all my Workstations onto the LAN side and connect right away to the SonicWall Global VPN Client, i connect my DSL to WAN side "which has to be configured to a different subnet and cannot connect with
SonicWall Global VPN Client.....Do i have to setup a static route to the IP address or some other setting's?
  • Qneela May 11, 2010
    Which model of SonicWall are you running?
    Additionally, the VPN Client is meant to be used EXTERNALLY. Can you clarify your ultimate goal here? Is it to be able to use the client to connect to your home network when you are away?
    I have the same configuration you have described and should be able to work thru this with you.
    Problem Solver:
  • 35 Answers
Sonic is sitting on the gateway. so dont matter where u are still u cant get outside
Posted on Aug 13, 2008
Cisco vpn disconnection through sonicwall firewall
This may sounds obvious but have you forwarded the correct ports through sonicwall for your VPN?
If you have, do you have any QoS running, it could be worth checking that VPN has priority over VoIP etc.
Do you get disconnects all the time or is it only during busy periods? You may be overloading your server, perhaps it's time for more RAM.
Oct 31, 2013 | SonicWALL PRO 2040 (01-ssc-5703) Firewall
I am workiong from my home office but do not get throug to my firm ofice. I am connected with sonic wall global client, but when I try to ping the firm server but it doesnt answear.
It sounds like it might be an issue with the VPN client that is attempting to get to your server at the firm. If you are having issues, first contact the firm's IT department. If they still cannot get you connected then you will need to contact you ISP to make sure that they allow VPN connections.
Nov 11, 2009 | Citrix SonicWALL Internet and...
Sonicwall client won't connect to the internet
The default VPN policy rules prevent LAN access, also known as split-tunneling, since this creates a security risk (the ability of the VPN session to be hijacked or compromised through a covert channel).
If you are not the system admin, you need to talk to your system admin. If you are the system admin, then you need to review the documentation with respect to
http://www.sonicwall.com/us/support/kb.asp?kbsk=policy+allow+lan
Oct 07, 2009 | Sonicwall PRO 3060 NFR (01-ssc-5378)...
I have a sonicwall pro 2040 and while the firewall rules look correct, I cannot get traffic from the WLAN to the LAN, nor from the WLAN to the WAN.
SonicWALL Wireless Configuration Wizard To access SonicWALL’s Wireless Configuration Wizard, log on to the SonicWALL router, then click the Wireless button found within the left navigation bar of SonicWALL’s Web-based management interface. The Wireless Status page will be displayed. Click the Wireless Wizard button that appears toward the top-right of the screen.
The SonicWALL Wireless Configuration Wizard will appear. Click the Next button to proceed with the wireless administration utility.
The wizard’s first step will appear as seen in Figure A. Step one addresses wireless local area network (WLAN) network settings. You must specify the WLAN IP address and subnet mask before continuing. In addition, a checkbox is provided for enabling Windows networking support between the wired local area network and the WLAN. Be sure to check the box to enable communication between the LAN and WLAN. Then, click Next.
Step two requires setting the Service Set ID (SSID), radio mode, country code and channel. The SonicWALL wizard provides a blank field for specifying the SSID. The default SSID is sonicwall. Consider changing the SSID to a value that reveals nothing about the organization or office in which it is deployed. I typically deploy SSIDs as HomeNetwork and BusinessNetwork, as doing so provides potential hackers with less information about a network (particularly in more heavily populated areas such as apartments and office parks).
On most SonicWALL routers, including the popular TZ 170 wireless model, three radio modes are available: 2.4GHz 802.11 b, 2.4GHz 802.11g or 2.4GHz 802.11g and b Mixed mode. Using the provided drop-down menu, select the mode you wish to use within your organization.
The last item to configure within Step 2: WLAN 802.11b/g Settings is the channel. Channels one through 11 are available options. Or, AutoChannel is an alternative choice and, in fact, the default. Choosing AutoChannel allows the wireless network equipment to automatically negotiate the best channel settings. Once the channel is specified, clicking Next continues to the next step.
Step 3: WLAN Security Settings enables configuring one of three security modes for the
SonicWALL wireless router. The three security mode choices are:
  • WiFiSec VPN Security – The default selection, WiFiSec VPN Security creates an IPSec-powered VPN over which the wireless traffic travels.
  • WEP + Stealth Mode – Utilizes Wired Equivalent Protection (WEP) to secure wireless communications.
  • Connectivity – Implements wireless communications featuring no encryption or access controls.
When selecting WiFiSec VPN Security and clicking Next, the Step 4: WiFiSec – VPN Client User Authentication page appears. This step helps create a user name and password for a new user with VPN client access privileges. The WLAN WiFiSec security setting will enable the SoniCWALL Group VPN feature. If you wish to edit user privileges, you can log on to the SonicWALL router’s Web-based administrative interface and edit user permissions by clicking Users | Settings.
After a user name and password are supplied, click Next to proceed to the wizard’s fifth step. The Step 5: Wireless Guest Services screen allows you to enable guest wireless access while also specifying the guest account name, password and account and session lifetimes.
Once these values are supplied, click Next to view a Wireless Configuration Summary. Clicking Apply prompts the SonicWALL Configuration Wizard to apply the settings and configuration parameters you’ve entered into the wizard. When the wizard completes, a confirmation page should then appear (with a Finish button being the only available option).
May 19, 2009 | Computers & Internet
Shared folder isn't visible when connected to VPN
this is an IT issue, your profile may need to be updated
Apr 26, 2009 | SonicWALL Global VPN Client for PC
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
VPN Connection problem with DSL
contact your ISP and ask them to enable IPPAssTHROUGH on your system.
make sure the ports::
TCP 10000
UDP::500, 4500 should be open
Mar 30, 2009 | SonicWALL Global VPN Client for PC
Private network > VPN > network firewll > priv net
Add a static route on the Sonicwall 2040 : 192.168.1.0/24 with the RV082 as gateway (the ip of the network shared between the RV082 and the Sonicwall)
Another solution is to enable NAT on RV082 for 192.168.1.0/24 network. Routing is preferable.
Feb 14, 2009 | Linksys RV082 10/100 8-Port VPN Router...
Cannot connect to SonicWall VPN
My guess is that dhcp is using the same private network scheme. Try changing your home network scheme to something different than your office.
For example:
Office = 192.168.1.x
home = 192.168.2.x
Aug 26, 2008 | Westell Wirespeed VersaLink...
Computers & Internet Logo
1,081 people viewed this question
David Payne
David Payne
