Question about Friedrich M18CE Air Conditioner
Hi i have a friedrich wall mounted unit /
Unit was working / power went down in the whole house , power came back unit started working but can not shut unit,controller is working i see the temp[rature high and low how do i get the unit to recieve signal thx in advance
  • 340 Answers
SOURCE: Friedrich a/c zq10 thermostat won't kick in
likely is the thermostat or could be the compressor going out on over load compressor runs blows cold air trips out on the over load fan will stay running jumper out the thermostat see if it stays running.like1/2 hr. if it does replace the thermostat not hard to change if you can find one.Tom
Posted on Jun 18, 2009
  • 6 Answers
SOURCE: wall unit leaking water in the front
should i poke a hole in the bottom right corner?
Posted on Aug 07, 2009
  • 588 Answers
SOURCE: friedrich quietmaster fan does not come on and
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Posted on Aug 25, 2009
blueextc3221
  • 15935 Answers
SOURCE: how do you mount a friedrich km14j10
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
bobicehouse
  • 1524 Answers
SOURCE: I have a Friedrich thru
Warmer you press > up arrow
Cooler you press < down arrow
Posted on Aug 17, 2011
Friedrich quiet master KS12L10 leaking water down outside wall and windowsill.
it may need coil cleaned. there is a drain hole under evaporator coil that might be stopped up.
Aug 12, 2014 | Friedrich QuietMaster RS10J10 Air...
I have a frederick x star Its a wall mounted unit and is excessively noisy at the beginning of a cycle or start up it does not appear to be loose in its mounting though why is it making the noise
This often happens when units get a little age on them. But, they quiet down after 30 seconds or so. Be sure the unit is tightly secure in the window, as the vibration my be caused in part by the unit moving slightly in the window.
Hope this helps you and thanks for choosing FixYa.
Jul 28, 2011 | Friedrich XStar XQ06J10 Air Conditioner
Why is there no drain hole for condesation to drip out?
Some of the Friedrich units will drip out in the back of the unit. There may be just a small bend in the base of the unit allowing a certain amount of draining just behind the rear coil. Most units require some water to remain in the back of the unit to help cool the unit off. This is why tilting in the window is important. Be sure not to tilt it too much or too much water will drain, causing the unit to overheat. Be sure to tilt it enough to where the water can drain properly or the water may drain in the house, down the wall.
Jun 20, 2011 | Friedrich CP18F30 18000 BTU ThruWallWindow...
I have a friedrich window unit el25j35. the heat went out last night
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 08, 2011 | Friedrich EL36L35 TwinTemp® 36000 BTU...
We have model # MW09C1E/MW12C1E indoor unit - wall mounted type Has started to leak water - not sure if it is the pump that has stopped working - we have cleaned the filters and the vents in the front...
Many do not have a pump and the drain simply plugs... blow it out with air...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Friedrich Heating & Cooling
Friedrich KStar KQ06J10 Air Conditioner not Cooling?
mcdevito75 here, Put the fan on and wait 3 minutes, NOW turn to low cool and place temp to 0 degrees or 1/2 thru the blue section of the cooling knob. Unit should work fine. type in online the unit name plus.com for any other assistance manuals, etc.
Jun 22, 2010 | Heating & Cooling
Best height of inside unit of a split AC
which type of mounting is suggested wall or ceiling, if it is suggested that wall mount is nominal then the height is optional, mount it as high as possible. If ceiling mount is suggested then closet to outside wall as possible
Jul 26, 2009 | Friedrich QuietMaster RS10J10 Air...
Leaking A/C
are there some instructions on how did you install them?..it should just be the reverse. in some units, they have small screws at the sides that secures the unit from its shell.
start with the face cover, remove it if you can. some units have a scew at the middle of the face cover before you pull out the filter. if you were able to pull the face cover off, then try to pull the unit and the shell should be left behind still attached to the wall. if this is not the case, then you should pull the whole unit including the shell or casing as others called them.
look for some securing screws or bolts that hold the housing. then if you were able to bring down the whole unit, start removing all the screws all around the unit in order to remove the housing and you can see the dirt on the drainage .
i hope i was able to solve you problem..
pls rate me
tnx for using fixya.
drcool
Jul 22, 2008 | Friedrich CP12C10 Wall/Window Air...
Friedrich M18CE Air Conditioner Logo
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
