PS3 MoBo Reflow Guide
This will only fix certain motherboard issues. This fix will solve YLOD issues cased by the system getting so hot the CPU / GPU or direct chipsets get shifted. This fix uses a heat gun to heat up the CPU / GPU and direct chipsets and allows them to fall back in place.
I used a standard heat gun (dual, High, Low settings). Check the temp on it though. You want it around 700-750 degrees Fahrenheit.
Some Additional Tips Not In The Guide:
after following that there are 6 more parts to it ... (linked in the Description of that Video)
It is completely broken. It can only be fixed by specialists or Sony if it is still under warranty.
Hi Kim,
If you are getting the YLOD or
yellow light I will run through what causes it and how you can fix it.
Causes:
The yellow light is caused by internal overheating and the main chips that take
the damage are the GPU and the CPU.
You need to stop the heat build up and you will be able to get back to gaming
again.
Solution:
You can either send the console back in for repair and they will fix it for
you, however it will take about 4 weeks to get this done and it will cost about
$150 for the repair!
Quicker Solution:
For a faster way to fix it you can use a good YLOD Repair guide that
will show you with videos how to stop the heat build up and get back to gaming.
The important thing is to make sure that you get a guide that is up to the job!
I have put together a list of the best PS3 Repair guides and a complete review
below:
Click Here To See The Best PS3
Repair Guides
Hope this helps.
Other Problems That You Can Fix Today Are:
PS3 Freezing Up
PS3 Will Not Read Games
PS3 No Display
PS3 Error Codes
PS3 Red Light
PS3 YLOD
PS3 Red Screen
Check out the full site and get a 1
hour solution...
Hi Melissa,
Causes:
again.
Solution:
Quicker Solution:
below:
Repair Guides
Hope this helps.
PS3 Freezing Up
PS3 No Display
PS3 Error Codes
PS3 Red Light
PS3 YLOD
PS3 Red Screen
hour solution...
Causes:
again.
Solution:
Quicker Solution:
below:
Repair Guides
Hope this helps.
PS3 Freezing Up
PS3 No Display
PS3 Error Codes
PS3 Red Light
PS3 YLOD
PS3 Red Screen
hour solution...
Alternatively you can try to repair ps3 YLOD yourself. There are a couple of things you can try to fix YLOD - check for any loose connections since some connections might be loose, you can also try switching it off for around 30 mins and switch it on again. This will help in cooling your PS3 down.
If these tricks don't work, then I will suggest you go through a dedicated PS3 repair guide instead of tinkering on your own. Such guide will cost you almost nothing in comparison to what Sony charges. And, god forbid, if it happens again you can solve the problem for free.
One of the greatest thing about doing it yourself is that you don't have to pay hefty charges to the big companies. Also, you don't have to wait for weeks, you'll completely fix ps3 ylod in no more than a few hours. Many people have already successfully fixed yellow light of death and I don't see a reason why you won't be able to do it. If my PS3 has yellow light of death then I won't pay Sony to repair my PS3. I'd rather fix PS3 lights myself.
If all this steps wont work i suggest to call SONY
PS3 Red/Yellow Light
If you are seeing this error it is
because the GPU and the CPU have overheated and you will need to stop
the heat to fix this. You can send the console in and they will fix
it for you but it does take about 4 weeks to fix.
You can quite easily fix this with a
few household tiems from home.
Check out this link for a full
solution:
