Question about Cyberguard SG300 (00852503000366) Firewall
Sg300 TST light blinking non stop
I reset the SG300 and still unable to get traffic through the unit and the TST light blinks nonstop. Did a reset from within the config table, no luck there either
4 Suggested Answers
SOURCE: Cyberguard SG300
From the main configuration screen select Network Setup, and then click on the Connections Tab. In the tabline below that click on Aliases.
At this point you input the Alias IP address and the netmask and add it, selecting port 25. The firewall now knows that it is to forward all traffic on port 25 to the computer that has the IP address you put in.
You should be aware that doing the above opens a direct access point into your network! Port 25 is the port used for SMTP (Sendmail) and it is the most vulnerable and most hacked service on the Internet! You should seriously consider not doing this.
A better option would be to goto the DMZ tab and configure a DMZ net on your firewall - you will need to obtain a second routable IP address from your ISP to do this though. By creating the DMZ and then routing port 25 to a machine inside the DMZ you isolate the machine running SMTP from all of the other machines inside your protected network and so make a compromise much less likely.
All of the systems inside your protected network will still have demand access to the machine in our DMZ, but the machine in your DMZ would be unable to initialize access to the protected network, which is a much safer setup.
Posted on Nov 15, 2007
SOURCE: Need to network SG300 Firewall and Qwest (Motorola) 3347-02 Modem
The modem needed to be set to a 192.168.x.x network, and the SG300 Firewall WAN port needed to be set to a dummy IP on the same network for it's IP, and the specific 192.168.x.x address for the gateway and DNS.
Posted on Nov 11, 2008
tjt3
  • 44 Answers
SOURCE: locked out of HTTP inside port on SG300 - telnet works
I was unable to supply a link to the manual for this product so I downloaded it to one of my sites to make it available to you. Here is the link:
http://www.dscmain.com/snaplink/sg_314_ug_revA.pdf
Please let me know if this helps...
Tim
Posted on Mar 25, 2009
Switch hub lynksys sg300 blinking
Normally its firmware issue update your firmware
Till you facing this issue means replace the antennas
Jul 20, 2014 | Linksys Cisco Sg300-28 Ethernet Switch -...
Locked out of HTTP inside port on SG300 - telnet works
Tim
Mar 23, 2009 | SG300 (SG0126US) Firewall
Can tlog in sg300 using a satellite remote access
Accessing a VPN through a BGAN should be fairly simple. It sounds like some of the settings for the VPN might have changed. If you changed any settings on your computer, or if you have added any type of security settings or firewall. If you need any assistance with your BGAN let us know. We do sales of Satellite internet terminals such as Thrane & Thrane, Wideye Sabre, Hughes, Fleet Broadband, and much more. We also do repair of Broadband satellite terminals. You can visit our website at www.BlueCosmo.com, or call us at 877-258-3496.bcrepairs.png
Dec 31, 2008 | Secure Computing SnapGear SG300...
Nov 05, 2008 | Cyberguard SG300 (00852503000366) Firewall
Mitsubishi 65 medallion hdtv 1080
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
this has how to fix the blinking light check out this forum for more on this type of stuff
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?2/108250
Aug 27, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Help with a unblock code
ok, on the internet window, click on tools, then internet options, then go to the ADVANCED tab, and click on the reset buttons and hopefully this fixes ur issue and if it does dont forget to rate me as FIX YA
Feb 12, 2008 | Cyberguard SG300 (00852503000366) Firewall
Cyberguard SG300
Oct 19, 2007 | Cyberguard SG300 (00852503000366) Firewall
Cyberguard SG300 (00852503000366) Firewall Logo
566 people viewed this question
Top Cyberguard Computers & Internet Experts
David Payne
David Payne
Are you a Cyberguard Computer and Internet Expert? Answer questions, earn points and help others
