Question about Western Digital My Book Premium ES Edition WDG1SU5000 500 GB USB 2.0 Hard Drive
MYBOOK PREMIUM HD Delayed write failure?
I have had my WD MYBOOK for a little over a year and I am not pleased with the performance. Every time I attempt to read or write to the drive, I get a Delayed Write Failure, data hes been lost error. I have attempted latest drivers multiple times, I've researched a dozen forums, I've even gone as far as editing registry and adjusting pagefile size and misc. other suggestions, and so far nothing has worked. Luckily my data has never been lost contrary to the error message, but it is incredibly frustrating as I purchased the drive for the purpose of backing up my system. I have noticed that the problem is less likely if I read or write in very small increments, ie approx. 350MB or less. But is an incredible pain in the neck to do so. PLEASE HELP ME, I'M DOWN TO MY LAST NERVE WITH THIS THING!!!
  • stevenclark Dec 14, 2008
    I've had the same problem with the USB connection on the My Book. It seems almost every time I install some new software the USB hub drivers get altered in some way, leading to write delay failures. The drive seems very temperamental about the drivers it uses. The only solution I've found is after any new software installations (sometimes even Windows updates) in Device Manager I uninstall all the USB drivers, unplug the drive's power adapter and USB cable (from the computer, not the back of the drive), then plug in the power again, then the USB cable. The drivers install and it seems to work fine until I make other system changes. Its an annoying hastle, but it seems to work.
  • 95 Answers
Most likely the drive has bad sectors. You should get it replaced it and don't store any valuable data on it.
Posted on Nov 08, 2008
WD My Book-Delayed Write Failed-Can't access-Files deleting!
Hi when you buy a hard disk you do not get instructions on how to change from FATS to NTFS. Your hard drive is set to FATS by default,which limits you tranferring files up to 4GB.If you changing to NTFS does 2 things. 1.you can transfer bigger files.
2. You will lose all data on the drive so you have to save any files to another drive ect
To change to NTFS, go to Start then Right-click on My Computer and select Manage. Under Storage click on Disk Management. Now find your hard drive in the list and Right-click on it and select Format. Under File System change the Answer to NTFS and leave the Allocation Unit to default.Click on Perform Quick Format if you want. click OK and confirm your OK with losing all data on the drive,and your done.
Regards Bill
Apr 18, 2010 | Western Digital My Book Essential Edition...
I lost the power supply for my WD2500 external HD.
My Book Essentials
12 Volts
3.0 Amps
36 Watts
Sometimes WD will even send you a replacement free of charge, if you give them a call.
Jan 24, 2010 | Western Digital 250GB MyBook External USB...
My WD Mybook TByte HD is not being recognized
There could be many reasons, but I had the same issues.
It turns out I had mistakingly swapped the 12v DC PSU with another one, the drive would light up, it would click but that was it. Nothing. Gave me the runaround for ages. Seems they need more current than the little PSU I was trying could deliver, so I swapped it for a 2 amp supply and it works fine.
Mar 13, 2009 | Western Digital 250GB MyBook External USB...
Dead WD Mybook Premium Edition
You could try recycling to see if they give you anything for scrap. I'm sorry to say that it would be worth nothing any other way.
Dec 20, 2008 | Western Digital My Book Premium ES...
I have two wd mybook, how me register them on my PC?
If windows 98SE, go WD website and download drive. If you have windows xp, just plug it in and it should auto detect.
Sep 18, 2008 | Western Digital My Book Premium ES...
I just drop my WD external hard disk (Please help)
When you drop your hard drive for more than a few inches, you just have to face the fact that the HD is dead, period. If for some miracle the drive still works, then it's the work of Jesus/Shiva/whatever deity of your choice. I'm sorry I can't offer anything more constructive. See Myth 24 on this page:
http://www.techarp.com/showarticle.aspx?artno=84&pgno=5
Sep 15, 2008 | Western Digital My Book Essential Edition...
Problem turning on hd
WD = Western Digital , 250Gigabyte external USB drive.
This is where you may need to perform all the USB checks and trouble shooting in the book + load any driver software that came with the drive.
also I would need to know what motherboard and what operating system you are using before I can help farther.
normaly windows 98 and 98 se did was just not able to make proper use of the USB ports , also on nforce2 motherboards service pack2 was required to enable the USB 2.0 feature
we are constantly lied to by the computer industry so get used to it untill the feds crack their skulls.
and remember if it's not hebrew , it's a lie :-> lhime shalom.
Sep 08, 2008 | Western Digital 250GB MyBook External USB...
Wd external hd
not possible. i suggest 24/7 antivirus monitoring.
Feb 15, 2008 | Western Digital 320GB MyBook External USB...
Wrong Power Adapter
Yes.If the voltage range exceeds the limit,"astalavista baby."
If the voltage is was below recommended,try plugging in Power Only,turn on,leave for a minutes.This should adjust the voltage regulator back to normal.
Feb 04, 2008 | Western Digital 320GB MyBook Premium Ext...
WD MyBook 320 GB Premium - Retrieving Data
You should buy a program called "Partition Table Doctor". I went through the EXACT same thing and it was just a bad partition on my mybook which is the EXACT same as yours is. It cleared up the problem for me. I still have problems with my mybook so i wish that I bought a different hard drive, but oh well.
but try "Partition Table Doctor", it will scan your mybook and fix any partition errors with it.
I was in the same boat as you over a year ago and trust me, "Partition Table Doctor" is a LIFESAVER!
Jan 13, 2008 | Western Digital 320GB MyBook External USB...
Western Digital My Book  Premium ES Edition  WDG1SU5000 500 GB USB 2.0 Hard Drive Logo
301 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
