Question about Sennheiser RS 110 Consumer Headphones
No power to transmitter rs 110
I cannot get the transmitter to turn on when I plug in the AC adapter. It worked when I first tried it but it has not since.
  • 2 more comments
  • Anonymous Sep 28, 2008
    turns itself off every 5 min to extremely loud static
  • miel1 Nov 17, 2008
    same problem - no power to transmitter.
  • Anonymous Dec 09, 2008
    The Power LED never lights up anymore... Worked for over a year and then suddenly went out.
  • nvchu Dec 11, 2008
    I have the same problem.  The thing worked well for almost a year and all of a sudden, no more power to the transmitter.
It powers only when there is sound input
Posted on Aug 01, 2008
Turn up the volume on the TV or stereo the transceiver is hooked up to. Make it quite loud. Now the transceiver will turn on. At least, after much hassle, that's what worked for me.
Posted on May 19, 2012
Display says "base unit no power" Is this fixable?
this is not a battery issue the actual unit that plugs into the phone socket and has a radio transmitter has no power. Look at the AC adapter plugged into the power point of the radio base device. Most likely someone has unplugged it or the AC adapter has gone faulty.
It is fixable check the AC adapter is plugged in and the power point is switched on. you should be able to buy another AC - DC adapter if it has gone faulty.
Dec 31, 2014 | Lands Phones
No power sennheiser rs120
Probably a defective item, Try for a return.
Oct 13, 2014 | Sennheiser RS 120 Consumer Headphones
Mini hp 110, Im not at home, need my computer. won<t boot, F11, F8, hardboot wont work... what can i do! I have 3 years of pictures on it... find me a efficient solution RIGHT NOW! :(
First try Hard Reset:
1. unplug ac adapter then remove the battery.
2. press and hold the power button for a minute.
3. put the battery back, plug in ac adapter.
4. turn on the mini .
if it does not work, see if light glows on the power jack.
then remove and reinstall the hard drive.
see if it works .
Jul 14, 2011 | HP Mini 1000 Netbook
THERE IS A LONG TIME AGO SINCE I DONT WORK WITH MY MICROTEST PENTASCANNER AND I DO NOT KNOW IF THE AC ADAPTER HAS AN OUPUT OF 9.VOLTS I AMP AC OR 9 VOLTS 1AMP DC PLEASE TELL ME WHICH IS THE RIGHT AC...
An AC adapter should output DC. The device should say next to the power plug what voltage input it requires. Also, check the AC adapter, it may say something like "Input 110-120VAC Output 9VDC".
Apr 26, 2011 | Microtest PentaScanner 350 (8180-00R)...
Bought my headphones in South Africa, now living in the UK. My AC adaptor to power my charger of my headphones is not functioning properly. Could this be caused by the incorrect power adaptor, as it...
Welcome to Fixya. You can check if the power output in South Africa and UK is the same. If you have 110 or 240V in africa check if the Voltage in UK is 110 or 220V aswell. If it is the same it only means that the adaptor is bad. If you can go to a store in UK find an adapter that is compatible with the headphone you can test it and see if it will work.
Thanks for using Fixya.
Mar 12, 2011 | Sennheiser RS 110 Consumer Headphones
The blue light on the transmitter is not coming on. It had begun to alternatingly be on/turn off. What is the problem?
Hi
Check that the transmitter AC power adapter is fully inserted into the wall outlet and the power cord from the AC adapter is firmly connected to the transmitter power input jack. So if you
Jan 05, 2011 | Cables Unlimited Audio Unlimited 900MHz...
I have a Prolink wireless 900 Mgh wireless speaker system. I have just moved and have lost the plug in adapter for the transmitter. could you tell me what the adapter voltage is into the transmitter. ...
I have Prolink 900 MHz wireless loudspeakers, probably the same as yours. The transmitter is labelled on the bottom as "CAN 2579 102 1811, UNI-ART PRECISE PRODUCTS LTD". That transmitter comes with an AC/DC adapter whose output is labelled as 12VDC, 300mA, with polarity positive outside, negative inside. Note this polarity is the OPPOSITE of what is typical for AC adapters.
Sep 14, 2010 | Audio Players & Recorders
Not charging
which green light?
light from the ac power adapter or the light from the battery?
if ac power adapter you are referring to try a diff power wall socket if ac power adapter still off then replace ac power adapter alone.
if battery light is off but the laptop works fine with ac adapter alone try updating the laptop BIOS.
if ac adapter light turns off when it plug to the laptop replace motherboard.
Oct 13, 2009 | Dell Latitude D531 PC Notebook
No sound thru my Sennheiser RS 110 headphones!
check with the manufacturer's website . Perhaps they have technical support
Jun 01, 2009 | Sennheiser RS 110 Consumer Headphones
Voltage
110 only ok
Feb 08, 2008 | Insignia NS-PDVD9
Sennheiser RS 110 Consumer Headphones Logo
1,259 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
