Question about Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum
Bissel 3594-1 release lever
Hi - I ordered a replacement relese lever because it broke on my vacumm, and I can't seem to figure out how to remove the broken one/replace with teh new one. Can you help?
Thanks!
Cindy
  • 937 Answers
Flip over the vac and use a long skinny screwdriver to spread the tabs that capture the two nubs on either side of the lever then pull the old part out. Then simply align the new part, and press it down into the slot till it clicks in place.
Posted on Sep 23, 2008
My belt broke on my bissel upright.it dammaged something.now my vacumm rooler brush dosnt want to turn.somethings bent
Not enough info to help fully. I'd call Bissell Consumer Care at 1-800-237-7691 Remember, you don't have the knowledge of seeing the inside before but they should have a troubleshooting guide to walk you thru it. Good Luck. Hope that Helped.
Sep 10, 2015 | Bissell Vacuums
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
I need to replace the belt on my Sharp Vacuum Cleaner: Model ECTU4609. Can't find Owner's Manual and can't figure out how it goes on .
i have replaced vacumm belts before .. Normally it is located underneath..flip over the vacumm unscrew some screws.. open the cover..youll see a large roller pin type object remove it carefully noting how it is placed..pull it out.. and replace the belt...you can also clean off the debris while doing this..an added plus..for vacumm maintenace..
PLease indicate whether this has helped you at all ..Thank You
Jul 05, 2009 | Sharp Twin Energy EC-TU4606 Bagged Upright...
Powertrak bissel vacuum 6390/3910
it might have something stuck, check all the entrance suction sections, also give it little shake
Jun 14, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Bissel model 3594 has weak suction
clean the filter abovethe dust cup... and any other filters
Feb 16, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Bissel 3593Handle Release Lever/Pedall replacement
You need to replace slider release not just the handle. Take off the screws holding the black plate under the removavle canister the you will be able to see the slide release.
Nov 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissel vacuum cleaner
That is the problem with a bagless, but if you keep the filters clean it won't be quite as dusty.
Jul 02, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Foot Pedal Broken
For the handle release, part number is Detent Lever 2030052 Try bissell.com, or call a local repair shop, if they repair Bissell's, then they may have this part in stock. You shouldn't have to take it aprt, there 2 tabs on the release that fit into slots on the base, there move the slots so as to release the tabs.
Jun 21, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Self propell feature not working
You can order the lever for the transmission on line for about $16.00. It comes as a cable and lever assembly. I just took the top cover off and replaced the lever without doing the cable. The reason ours broke is because we lifted the vacuum by the handle without the self propel bing turned off, this pulls on the actuator and breaks it.
Oct 28, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Bissell Cleanwell II Bagless uprighht vacuum
Hi Pmob20,
Remove the brush and clean all the string or whatever may be trapped at the end edges of the brush.  This is usually the case with Bissel vacs, that string or fiber gets trapped at the ends of the brush assembly.
Oct 10, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum Logo
126 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
