Question about Malber WD1000 Front Load Washer/Dryer
DOOR HANDLE i HAVE A WD1000 WITH AUTO LOCK FEATURE THAT SOMEONE TRYED TO OPEN BEFORE TIME AND BROKE THE HANDLE. hOW CAN i GET ONE?
  • 4 more comments
  • fezi27 Aug 07, 2008
    Melber Wd1000 front door handle broken. Where can I get the spare handlle?
  • juliagirl21 Sep 01, 2008
    the handle is broken.What should i do?
  • Anonymous Sep 09, 2008
    door handle brook
  • Anonymous Sep 24, 2008
    the handle snapped when someone tried to open when they thought the cycle was over
  • frankm852 Feb 15, 2009
    Door handle broke on attempt to open. Where to order a new handle?
  • joesurf1 Apr 04, 2009
    need replacement door handle for Malber WD 1000
Email Malber at info@malberusa.com
Posted on Aug 07, 2008
Nissan pathfinder problems
Check childproof lock if you can open it from the inside, but usually the connection between the handle and the lock for the outside door handle breaks.
if you can't open the door using either inside or outside door handles, go to a locksmith, auto electrician or a Nissan dealer or risk severely damaging the interior door panelling trying to do this yourself...
Please get back to us with the solution you found worked as it may help someone else in the future, thanks.
Jul 07, 2014 | Nissan Pathfinder Cars & Trucks
Broke the door handle on malber wd 1000? Do they sell the handle or door?
Sorry to see this 16 months too late.
You can find Malber Distribution Corp online, or call them at 516-323-5299. Tell them Mike, in DC, says hi.
Oct 30, 2012 | Malber WD1000 Front Load Washer/Dryer
2000 pont. gr am pass door only opens when you use door key to unlock and pull handle at same time , the door lock are auto. you can hear it unlock but cant open it normally
there has been lots of problems with the power door lock actulator on this model . you will need to remove the door pannel and then remove the door lock latch assembly and inspect to see if the actulator is broke . If it is broke then you will need to replace the latch assembly as i dont belive that the actulator comes seperate from the latch . but check with your local parts store or dealer
Mar 04, 2011 | Pontiac Grand Am Cars & Trucks
How do I fix the door/lock of my 1991 Acura Integra? I can only open the driver side door from the outside
There are only 2 places that you have the problem on the inside door handle. one is at the handle,and the little plastic holder that holds the rod to the handle broke, or the plastic clip the the door lock mechanism broke. the first can be removed without taking the door apart. the inside door handle has a screw holding it in place. you can remove the handle and see if its broken. the second requires you to remove the door panel, to replace the clip that hold the rod to the lock. I door handle in the car is a dealer item only(sorry to tell you that), the clip for the lock, you can get at the auto parts store. hope this helps
Jan 11, 2011 | 1991 Acura Integra Hatchback
Need a new door opening handle?? the handle broke
You should be able to order one from Splendide. In the meantime, try using a screw driver to manually push the door release button.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Sep 22, 2010 | Splendide 2000S Front Load Washer / Dryer
I have a 1999 Astro and the dor will not open using the latch from the inside. Someone has taken the ashtray off of the door and I can slide my hand inside and move the leaver so that it will unlatch the...
there is a rod that goes from latch to the handle possible disconnected and was never reattached the rod is held in place with a plastic clip -any auto store carry them -other is handle broke and will need to replace whole handle assembly -salvage yard,online or dealer for part use a mirror to look in the door behind lock it u cant access the lock will have to pull door panel of to repair and or replace parts
Jun 14, 2010 | 2002 Chevrolet Astro
1999 Olds Aurora; Front passenger door won't open from inside or out. Feels/sounds like the lock mechanism is not catching. Can't get to the inside of the door to fix it if I can't open it to take the...
This may not be your answer but I had a similar issue a few years ago and had to have a body shop get into the door and replace the handle and linkage. Someone, a child, tried to open the door while locked. He was strong enough and/or handle weak enough that it broke. The door could be opened from the inside handle normally. Cost me about $180 for part, install and repaint to match.
Feb 04, 2010 | Oldsmobile Aurora Cars & Trucks
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
Driver door latch 1992 Lumina will not open door anymore
i think the clip broke off of the door handle inside of the door panel you have to take the panel off and look it is eather the clip[ broke or the handel is broke inside ,i would take it to a shop unless you have the tools and time to play with it just trying to help
Mar 20, 2009 | 1992 Chevrolet Lumina
Outside handle won't open the door
this is a special clip try a auto body shop and see if they can give you one they should if they would like you to come back Please rate my response thank you very much
Jan 28, 2009 | 1994 Mercury Cougar
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
261 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
