Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Start up and shut down
It takes 20+ minutes for my Dell to boot up. Once it has booted, I can not get into Internet Explorer. Then when I try to shut down, I can't close down anything. I end up holding he on/off button for a few minutes to make it shut down.
  • 3,940 Answers
Extremely slow operation can be the sign of many issues. The first of them is the hard drive failing. (I suspect this as the most likely reason.) You should be able to run hard drive diagnostics from the F12 menu. If they fail, replace the HDD.
If the diags pass, then next thing I would look at is free space available. At a minimum, you should have 10% OF THE HARD DRIVE free for Windows to cache data. Dropping below 5% usually effect dramatic slow downs and below 2% can prevent internet access too.
Other possiblities include Virus/Spyware infection
Posted on Sep 15, 2008
Keeps shutting off
Your internet explorer browser could be at fault. Try a different browser such as Chrome or firefox,. If they work then your problem is with the IE browser part of windows. If so, no big deal since the other two browsers are better and less memory intensive.
Mar 18, 2014 | Dell Computers & Internet
Dell Studio 1558 - No post/boot
maybe is the hard disk... u must try to log in with a live usb linux (or windows or hirens boot cd ) and watch if it logs.. if u want to check fan if its covered of dust ill let u a link of how to open it http://www.youtube.com/watch?v=Hn_RX56oGqI
Feb 28, 2013 | Dell Studio 1558 Notebook
Dell 4700 power up to desk top then shuts down
check your cpu fan if still working. if it is working try to edit your bios to safe defaults and save it then boot up. also try to boot on safe mode if it is ok in safe mode then try system restore...if worst.. format your pc
Aug 10, 2012 | Dell Dimension 4700 PC Desktop
Dell demension 2350 shuts down after a couple minutes what is wrong?
The most likely situation is a file error in the windows boot up process. Try booting the computer in safe mode (press the f8 key after the post screen, and selection menu will come up, sellect safe mode). If it does not boot this way, you could try a boot repair (since you did not list tthe brand model of computer, it is hard to direct you on this course). Most likely you will have to do a full restore to clear the error. This of course will remove all software, data that was not installed on the computer out of the box.
Feb 08, 2012 | Computers & Internet
Carresearch, I just put the cd in and restarted the computer but the reinstallation didn't start. How do I reboot the cd first?
OK, Here's what you need to do. Shut down the computer. When you restart it, as it boots, continue to press and release the F2 key as the computer starts up. When it does, you will get a BIOS setup screen. From there, there will be an option to change boot sequence. Make CD drive first and then C: drive. Save your changes and then reboot. This time, the computer should load your reinstall disk. Let me know how it goes.
Apr 03, 2011 | Dell DIMENSION 3000 CELERON 2.4GHZ...
It is taking 15 to 20 minutes just to pull up internet explorer, computer is very slow. I have deleted a lot of unused files and ran a Norton 360 scan and it is still very slow. The Model is ELI300G
Start in safe mode with networking (hit F8 repeatedly after the boot splash screen), Open Internet Explorer, go to TrendMicro.com and run their free virus scan.
Aug 22, 2010 | Acer Computers & Internet
Hi, my brother has a Compaq Presario 5000, and is having some trouble. The computer will boot to a point and then simply shut itself down. The point to which it gets before it shuts down is variable: it...
Once try to Re-Install your Operating System and Just after Installing your OS just once Mo niter your CPU usage in Task Manager if it is Simply raising to 80% to 100% then it is a issue of over heating
Aug 11, 2010 | Compaq Presario 5000 PC Desktop
Laptop intermittent startup problems
if you need your laptop always in ready use change the time your computer is on in control panel then log off your device will be on always until you shut it down it constantly drains battery
There is a way to fix this try reinstalling windows
or just take it to software mechanic
Mar 21, 2017 | HP Compaq Presario v4000 Notebook
Overheats and shuts down after about 20 minutes
Usually when a CPU overheats it shuts down and after it cools down you can re-boot it again.
Continual overheating will eventually cause the CPU to fail.
The overheating is usually caused by blocked vents and or dust build up on the heatsink and/or fan. Remove this dust from the heatsink and fan and this should fix your overheating problem, unless you have a faulty fan, in this case you will need to replace the fan.
Feb 18, 2009 | Dell Inspiron 2650 Notebook
Lenovo booting problem
so u;re saying that the BIOS tests are taking 10 minutes ?! Usually that happenes when the computer shutes down brutally (after power surges, by removing the battery ... by forced shut down). Try doing a BIOS update, and also set it so it will skip some tests or not to do through testing ....
Aug 08, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
83 people viewed this question
Alun Cox
