Question about Nikon Coolpix 990 Digital Camera
Coolpix 995 hard drive????
Does it have one. If the failure of it is a common problem with the 995. Taken it to bits and can see no hard drive in it.
Cheers
    Problem Solver:
I'm sorry for any confusion, I am no expert by any means but that is what the person told me at Wolf Camera. I did see him get the parts/repair book out and he showed me the price it had listed for that repair. I don't know if it will help you but this store is in Nashville,TN located at Hwy.70. Maybe you can call them. Thats all I can tell you, good luck.
Posted on Jul 29, 2008
Nikon Coolpix 995 gets a CF.Er card is not formated
bens pins inside on the camera , need to fix the card holder unit
easy to fix
Oct 09, 2017 | Nikon Coolpix 995 Digital Camera
My nikon coolpix 995 won't download pictures
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Nov 04, 2010 | Nikon Coolpix 995 Digital Camera
Can i use my coolpix 995 as a web cam
Although you can use the camera in monitor mode, the only way to make it work is by using an analog to video capture card to take the monitor signal to digital. i do not know of anyone who has done this or what software to use to then convert it to webcam use.
Nov 09, 2009 | Nikon Coolpix 995 3.3 Megapixel 4x...
Rdr hxd 995. Says 'no disc'. Can't access hdd.
The E01 error is a hardware error with the drive. I would try a new disk fist to see if it's just having trouble reading the one you're using but if that doesn't work it's most likely a failure in the drive itself and needs to either be sent in for warranty or replaced.
Hope this helps,
Chris
Aug 19, 2009 | Computers & Internet
Blurred picture with nikon coolpix 995 macro mode
When shooting in macro to get good depth of field you often have to shoot f/22. This does not let much light in. You have to hold the camera and subject tight. Meaning the use of a firm tripod is not optional. In most cases you need a longer exposure so wiggle is very important.
Jan 20, 2018 | Nikon Coolpix 995 3.3 Megapixel 4x...
CF Card for Coolpix 995
Hi - You can download the manual by clicking the link underlined in blue below:
Coolpix 995
See page 162:
So it seems that only 128 Mb is officially supported, however elarger cards may be OK but you would need to try, don't forget to format the new card in the camera. You may find a friendly high street shop that will let you try various card to see.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 03, 2008 | Nikon Coolpix 995 Digital Camera
Coolpix 995
Wolf Camera diagnosed the camera and determined it to be the hard drive and given that I threw it away and bought a new one. The cost would have been over 200.00 to fix it. They said it is a common problem with the coolpix 995. Goodluck!!
Jul 28, 2008 | Nikon Coolpix 990 Digital Camera
Overexposure
CoolPix 5700's have a common image sensor failure. Check with Nikon for recalls, this may be the cause of your issue. Alternatively the shutter may be stuck open, causing too much light to reach the sensor and causing over exposure as well as lines across the image. David Millier Advance Camera Repair
Mar 11, 2007 | Nikon Coolpix 5700 Digital Camera
Coolpix camera not recognized by Windows XP system
When a mass-storage class (MSC) Coolpix camera (Coolpix 775, 885, 995, 2000, 2500, 5000, 5700, D100) is connected to a Windows XP system the camera does not appear as a mounted drive if there are no free drive letters between physical drives and mapped networked drives. Remapping the first network drive and leaving a free drive letter solves this issue. For example: If the Floppy Drive is drive “A” the internal Hard Disk is “C” the CD-ROM is “D” and the mapped network drive is “E” the Coolpix camera will not mount. If the mapped network drive is moved to “H” the Coolpix will mount properly as drive “E”. To change the drive letter mapping: Find the mapped network drive in the "My Computer" Right Click the drive and choose "Disconnect" Use the "My Network Places" to find the share to be mapped (that was removed above) Right click the shared item and choose "Map Network Drive..." Choose a drive letter from the pop-up list, remember to leave at least one free letter after the last physical drive Click "Finish" the share will now be mapped to the new drive letter and the camera should mount As long as there is a free drive letter between the last physical drive and the first network drive the actual letters do not matter. For instance if there were more than one hard drive (or DVD, CD-R, etc). This issue has only been documented with Windows XP and MSC class cameras, cameras capabale of using PTP USB mode should be set to PTP to avoid this issue.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 990 Digital Camera Logo
46 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
