The revs run high to low when the air con is on????
    Problem Solver:
  • 7 Answers
Please provide actual information when you post a question
Posted on Jul 30, 2008
Can anyone tell me where I can locate the relay for the air con on my 2003 AUDI A4 130 sport 1.9tdi
If the relay is bad, It couldn't have been recharged. You need a set of gauges at minimum to diagnose the A/C system. High and low pressure. After the pressure test come the electrical part of it.
Jul 09, 2016 | 2003 Audi A4
Idle getting high when aircon is turned off
there should be a sensor that bumps the idle up when you load the engine by turning the air/con on
if this is unservicable the rev,s will stay high when air/con is off
Sep 17, 2010 | 1990 Toyota Corolla
I have a hb180 homelite leaf blower and want to know how to adjust the 'two' little screws on the side and what they do
if its the carb screws your talking about
one it for fule mixture the other is for air,,,
air for tickover fule mixture for rev's
if its running well leave them be?
Oct 30, 2009 | Garden
Air con recharged pump working pump stopped
I think,on this vehicle,there is a w o t switch.This is WIDE OPEN THROTTLE ,if so it may be bad.Also look for a short in the low side clutch cycle switch.I am not familiar with this model car,but basically they should all work on the same principle.If I can help,let me know.>>roniecon@gmail.com
Aug 19, 2009 | Peugeot 405 Cars & Trucks
Change my idle on my 2000 accent
alternator not pushing out little power to run air con on idle.Get it checked out.
Jun 04, 2009 | 2000 Hyundai Accent
My 1997 cadillac sts idles very rough
if it idles rough when air con is turnd on ur idle my be running to low to start with the air con is a pump and will take power from the engine and wen u turn on ur air con there is a clutch on ur pump witch engages witch will couse the revs to drop
Apr 26, 2009 | 1991 Cadillac DeVille
1998 Rodeo TF Series 2WD 5-speed manual
vacuum leak......bad tps.......bad mass airflow meter system........any of those are suspect...... also check for bad ground at battery to be sure all is not computer freak out from bad readings ...good luck
Oct 24, 2008 | 1998 Isuzu Rodeo
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
