Question about Samsung LN-R237W 23 in. LCD Television
Replace Main Board?
We have had the Samsung LN-R237W for 2 years. Enjoyed it until now. The screen keeps going from black to dark grey, no sound, and the TV will not go off unless we unplug it. At first we would hit the sides a couple of times and it would work but this solution no longer worked. Took it in for repair and they said it will cost $375 to replace the mainboard. We chose not to repair it. What is the cost of a main board and is it difficult to install. My spouse used to repair TV's many years ago, of course, not LCD . Or is there another solution to this problem?
Thank you. EJS
  • clemskid Aug 06, 2008
    Thank you for the reply and possible solution. Sorry for delay in responding. He did a thorough check for poor solder connections and did not find any.
    New question before we buy a new TV. What is the approximate cost and where do we purchase/order a new main board for this Samsung LN-R237W? Also, is it possible it could be the power supply instead of the main board?
    Thank you very much for your help.
  • 4,234 Answers
If he is familiar with soldering, try opening up the set and reseating all of the connectors and cables. Then look for poor solder connections and resolder any that appear "bad". Update this with the results.
Dan
Posted on Jul 29, 2008
Hello. My Samsung LCD model # LN-T3253H 60"/61"
It sounds like your LCD panel or your T-con board is bad . Panels are expensive so I would replace the T-con board first. You have to open the TV and get the part number from the actual board in order to find the correct one. You can find parts at www.interliquidparts.com
Jun 03, 2011 | Samsung LN-T3253H 32 in. LCD Television
My Samsung 32¨tv´s black
reseat your LVDS cable and clean both ends with lighter fuel. This shouls solve your problem if not upgrade your firmware . go to the samsung site on the web with model#. If you still have a problem replace the main board.
Nov 04, 2010 | Samsung LN-S3241D 32 in.LCD HDTV
Samsung 40" flat screen looses sound
this problem started on my LN-S4051D a couple of years ago. eventually the sound stopped working altogether. I then started using my surround sound speakers for the TV via optical out but soon that stopped working as well. I recently took the TV to a repair shop who said that the main board is bad and needs to be replaced. Labor plus parts was going to cost me $400. I said no thanks and paid for the estimate. Good luck.
Jun 27, 2010 | Samsung LN-S4051D 40 in. LCD Television
My Samsung LN-S2651D has sound but no picture
Check with Samsung, this model should still be under the 3 year warranty. You are having a problem with the backlight power supply. You can look on the back of the unit for the manuf. date, if its less than 3 years then go to www.samsung.com and process the online service request form.
I hope this helps,if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 20, 2010 | Samsung LN-S2651D 26 in. LCD Television
Samsung LN-T4661F with black shaded area.
The back light is beginning to fail, thats why it goes shaded but you can still the picture on one side, do a google search for back lights for your make and model, there a few how to's to help you with changing the back light.
Feb 17, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
How hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Mar 30, 2009 | Samsung 32 in. LCD Monitor TV
Sound yes, but no picture on tv
If you have sound on the stations this is a problem in the display. Take bright flashlight and hold it against the screen. Look for an image around the edge of the flashlight. If you see an image then it's one of three problems;
1) The inverter board is bad.
2) The CCFT (cold cathode fluoresent light) are bad.
3) The power supply to the inverter board is bad.
Someone knowledgeable in electronics can replace the bad part(s).
Dec 21, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
My Samsung LN-S4692D
before you give up..call samsung directly, they are very consumer oriented and if it is only a couple months out of warranty you might get them to repair it,, 1 800 samsung
Nov 20, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN-R237W 23 in. LCD Television Logo
219 people viewed this question
Henry  Thomas
Henry Thomas
