Question about Compaq Presario 5000 PC Desktop
Mouse troubles with my Compaq Presario 5000 PC
When i turn on my computer in the normal mode the mouse does not show up and i need to use the keyboard to move around, but when i went into safe mode the mouse shows up and is usable and is usable on other computers when i hooked it up to my other computer, so this proves that it is not the actual mouse that is the problem. how can i fix this?
  • Compaq Master
  • 3,051 Answers
Looks like to me that you have generic drivers loaded if you get to my computer right click on it and go down to properties then click on it click on hardware and than look for your mouse and right click on it and look for remove than click on it to remove the mouse from the computer say yes than close out of it and restart the computer once the computer starts up the new hardware found should pop up and continue installation from here ok good luck !!!!!
Posted on Aug 09, 2008
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
Keyboard and mouse won't work
Hi , Whats the system configuration .Do you have access to this pc via network or remote access, if you do you can get input drivers from here and install accross the network or by remote.
Code: http://www.input-drivers.com/
Jan 09, 2009 | Compaq Presario 5000 PC Desktop
Screen shows no signal
Hold down the power button for about 6 seconds continuously, this should wake it.
Sep 19, 2008 | Compaq Presario 5000 PC Desktop
Mouse trouble
start (button) select control panel / system / hardware / device manager / mice & pointing device / double click, select wheel mouse (or whatever mouse you have) right mouse click, properties, select use this device (enable) - But I'm surprised you are having trouble with it.. Have you changed anything recently? Have you always used a ps2 mouse? Try connecting the mouse & re-booting the pc.. Also make sure it's plugged into the correct port, not the ps2 keyboard port.. Especially checkif you are using a usb keyboard.. Rgds
Jun 08, 2008 | Compaq Presario 5000 PC Desktop
Computer beeps when first turning on
If your computer is still under warranty, the company should replace them. If not, you can buy them really cheap.
Or you could just return the computer. This is what I would do, because it might not be the mouse/keyboard that is causing this. It could be that you just have a bad motherboard.
May 20, 2008 | Compaq Presario 5000 PC Desktop
Computer will not respond to any commands
Make sure that the keyboard and mouse wires are plugged in the appropriate ports, if it still won't work, try switching keyboard and mouse. If it still will not work I would call the factory and try to have it shipped back because it could be blown ports.
I hope this helps some.
Apr 02, 2008 | Compaq Presario 5000 PC Desktop
Compaq presario S5300NX Mouse not working
Bill check the cables in back make sure its tightly plugged in. also restart your computer.
Feb 15, 2008 | Compaq Presario 5000 PC Desktop
Dead mouse port
Had u checked it with new mouse..
If showing same problem.. u need to replace the motherboard..
Nov 19, 2007 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
