The first thing I would check is the battery. If you have a battery and no CCA then you will get this kind of issue. Load check the battery. It could have full voltage but carry dead cells and have no power to crank the motor. If the lights go dim when you push the starter button this may be the issue also check battery for corrosion and bad grounds. Check the negative cable at the battery and all ground cables to engine or frame for looseness. Let me know what happens.
I’m happy to help further over the phone at https://www.6ya.com/expert/al_e83b1941f9c0f302
its a brand new batterie i ordered from a HD dealership, not to mention this starter is the original starter from back in 79 with total neglect added to it, im not blaming the starter i know that things a loss.Im gettin a new one 2morrow, but theres still something wrong there. (Starter kept spinning, getting the terminal hot 'n catchin the wire on fire, haa. lol i dont wanna risk fryin $300 cause a some faulty wiring. ill admit whoever had it before, jerry rigged the solenoid relay haha. I dont know, thanks though always appreciate some help
