Question about Whirlpool Microwave Ovens
Installation template for whirlpool MH115oXMQ3 micro/hood, where can I get one
  • Anonymous Jan 28, 2009
    I need a copy of the installation manual
  • Whirlpool Master
  • 9,098 Answers
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
Does the maytag mmv1164ww1 micro/hood combo require outdoor venting?
No .. it can also be recirculated . you will need charcoal filters if you do so. There is a specific charcoal filter for each microwave hood. Any appliance part dealer would carry it ( you will need to give them the micro hood model number ) or you can order them online through Whirlpool parts website ( whirlpool owns maytag)
Mar 14, 2011 | Microwave Ovens
I need the wall template for a jenn air micro wave oven model no.jmv8208ds
That is part number W10188240 and you can order it here.
You can download the installation instructions free here.
The owner's manual is here.
Dec 18, 2010 | Jenn-Air Microwave Ovens
Have whirlpool gold accuwave micro hood combo model# GH51884XPS5
The inspector is correct, air should be coming through the top louvers, although you sometimes will have a little air coming from the sides and back. Drop the microwave and see which way the blower is rotated, towards the louvers or towards the back or top. Some units also have a panel that blocks the venting from going the wrong way. Good Luck, Appliance Specialists
Dec 15, 2009 | Whirlpool GH8155XJ Microwave Oven
I bought a used over the range microwave oven( kenmore) I would like to know how to install it knowing there is an opening to the roof. thank you
Most Kenmore microhoods use a 3" by 10" exhaust duct. Check for correct demensions. Make sure that the existing vent is this size or that you have room to adapt to this size. There should be a damper mounted to the top of the micro which will attach to the vent duct work. You will need an outlet in the cabinet above the micohood. This should be on a circuit of it's own. The microhood should have a wall plate for the back wall. I'm going to assume there are no templates available. Hold the wall plate against the back of the micro to determine the height placement in the opening. Most install centered under and against the cabinet above. Not all do, so this will confirm. Mount the wall plate to the existing wall studs with at least 1/4" by 2-1/2" lag bolts. Bore an 1-1/4" hole in the right rear corner of the cabinet above, about 2" out from the back of the cabinet and 2" in from the side, this is not a critical measurement, it is to pass the electric cord into the upper cabinet. There are two screws that support the front of the hood. I believe they are 1/4" by 3-1/2" long. If not included, check for size. The hardwae will have them, get flat washers to fit both also. Measure from the back of the micro to the mounting holes in the top of the micro, include the wall plate in this measurement, they'll be about 10" out from the back and about 1-1/2" in from the edge, near the front, but check that measurement, they vary. Drill 3/8" holes in the bottom of the cabinet at these locations. If doing this alone, best that you move the range out. It's nice to have a helper at lifting time. With the plate on the wall and the holes in the bottom of the cabinet, your ready. Put the 1/4" screws and someting to drive them in the upper cabinet, so they'll be available. Lift the micro into the opening with the front tilted downward, hook the back of it into the bottom of the wall plate, push the cord into the upper cabinet, tilt the front of the micro up until you can start the front support screws. Start both, don't let go of the micro until you are sure that both screws are started and will support the front weight. Once you're sure, tighten both screws all the way and connect the vent. Steel tape is best for sealing up any leaks. Power up the outlet, plug in the microhood and put in the popcorn. Get a good movie and enjoy in your accomplishment. Congrats. PS: Make sure the roof vent opens when the hood is turned on, I have seen them stuck shut from grease build-up.
Oct 22, 2009 | Microwave Ovens
Need help in installing the back bracket on the wall for my jmv8208bas
If you do not have the original template you can hold the back plat up on the wall and mark the screw holes. Try to get at least 3 on studs. It will have to be down from the cabinet a little to allow for the micro to swing up into place.
Eric
Jul 02, 2009 | Jenn-Air JMV8208A Microwave Oven
GE JVM1650CH01 Microwave Template
You can download GE owner's manuals and installation instructions here.
Aug 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
I bought a used maytag model mmv5165aas over the range microwave oven and need the mounting templates and manual for it. and suggestions on where to find the or who is selling them other than...
You can download the owner's manual and installation instructions here.
You can usually find helpful exploded view diagrams and order needed parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 07, 2008 | Whirlpool Microwave Ovens
Microwave hood combination
Your best bet is to contact the manufacturer for installation instructions, and even an installation kit, since this will come with harware and templates.
If you can supply brand and model, we can steer you better.
Oct 13, 2007 | Microwave Ovens
Microwave Ovens Logo
834 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
