Question about HP Office Equipment & Supplies
Have hp photosmart c7200 all-in-one printer keep getting error messages when sending fax code 350* have done a test but all ok
Go to fax setting and change resolution to standard. Worked for me.
Posted on Jun 02, 2009
What to look for when it keeps saying ... Error .... Remove and check color Cartridge?
I suggest you run the 'Tap 10' diagnostic test pattern for your HP PS 2600 series printer model...this will display the electrical health of the ink cartridges and confirm that your printer is operational (I am guessing one of the ink cartridge control lines is open).
Good luck
Mar 06, 2013 | HP Photosmart 2610 All-In-One InkJet...
I keep getting error message 388 whenever I fax to any number. I have been able to receive faxes. My all in one is an HP officejet pro L7580
You probably need to run the fax test to check if the fax mechanism is working fine.
Click on Setup Button ( ranch like symbol ) on the printer front panel.
Scroll down till you find Tools ( press ok )
Check for Run Fax Test ( Press OK )
It will print the test results and everything should pass.
To solve your fax issue, follow the steps below.
Check for Advanced Fax Setup ( or Basic Fax Setup ) - Press OK
Look for ECM ( Error correction mode ) - Press OK
Turn the ECM OFF
Try to send fax. It Should work.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
May 16, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
I have an hp officejet pro 8500 fax, scanner, copier and printer. I keep getting an error message 350 when I have repeatedly tried to send a fax. What do I do and what does error 350 mean? Thanks in...
error 350 means a disconnection, from your machine to that of the remote fax machine. Disconnection can either come from a power shortage, defective or not so good telephone lines, a call-waiting mode on the telephone, a defective fax machine or manual interruption.
Sep 12, 2010 | Computers & Internet
Sent a fax and report came back with result message"error 390" What does that mean? regards Lisa
Hi Lisa,
According to the HP manual, this error code is consistent with a communication error. in other words, the machine tried to send your fax, but could not get anywhere.
I would:
1. Turn off the printer, then turn it back on. send a test fax to another number, see if it works.
2. check where your phone line connects to the printer, and make sure the phone line is plugged in to the correct phone jack on the device. If it is, take it out, and put it back in. Test sending a fax again.
3. If this doesn't work, test your fax line. hook it up to a phone- see if you can hear a dial tone from it. If so, the line is active. If not, you may need to troubleshoot for a phone line problem, which your telephone provider can assist you with.
4. If the phone line is alright, but the printer still doesn't work- something could be internally wrong with the printer. Call HP for further support, and they will be able to assist you by getting it repaired.
Jul 16, 2010 | HP Photosmart Premium C309A All-In-One...
I have a HP Photosmart All-in-One series C7200. I keep getting an error message saying "Image on Fax Teport is set to Off". Error 388. The proble occurs when we try & send long distance. What should I...
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
to check the error codes and there solution
click on the following link Hope you its satisfactory
ERROR CODES C7200 Series
Jan 03, 2010 | HP Office Equipment & Supplies
My C7200 Photosmart Printer/fax says " Origininsl Jam" .
If you are using DSL I suggest you to use filter. that will resolve your issue
Aug 19, 2009 | HP Photosmart C7280 Printer
When trying to fax connects ok but comes back failed error 388
A list of HP aio error codes:
You could try running the Fax test. Press setup > Tool> Run Fax test.
This will give you instructions about what you need to check and what you need to do if it failed on some of the tests.
Then try to send a fax to the HP fax test server detailed below:
Jan 19, 2009 | HP Photosmart 2410 All-In-One InkJet...
Wont send fax
Error 350: Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Try these steps...
1. Press setup, then go to TOOLS.
2. press okay on TOOLS, then look for RUN FAX TEST. then press okay.
3. It will print a fax test page. Check if everything passed.
4. If it passed everything, try to press setup again, then go to ADVANCE FAX SETUP.
5. Scroll, down and look for ECM (Error correction mode), then press okay
6. Under ECM you will have to options "ON or OFF" try to choose OFF then press OKAY.
7. Now, try sending a fax.
Please let me know if the steps that i gave resolve your issue or not. So that i can still go ahead and give you another possible solution.
Thank you so much.
Jun 29, 2008 | HP Photosmart C7280 Printer
263 people viewed this question
Ben Johnson
