Disconnected the Maxtor 4 500gb unit whilst away on hols, on return and connecting back up does not respond and shows no drive connected...... but it is!! Checked all cables and even tried different ports to no avail... Help!
    Scholar:
  • 180 Answers
Motor of the drive is jammed.if its making a a vibration felt on hands , then motor is ok, and the platter arm is stuck on the hard drive recording area. or the circuit plate is faulty.
Posted on Jul 29, 2008
Maxtor 320 GB mini not working
If it shows up as a USB mass storage device it:-
1. Has power
2. It is connected to the computer via USB.
3.The correct software has been loaded for the hard drive.
The beep sound is probably an error message saying that the drive is not responding properly inside the case.
Hard drives Drives have been known to stick or not start up due to power cables or ribbon cables being dislodged. Try pushing these back into place.
If this is not the problem go to the Maxtor site (maxtor.com) and report the problem with the drive, not the USB which appears to functioning correctly.
Mar 07, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
Problem open up my maxtor one touch 500gb to retieve photos
first, recover your files. You will need to use hard drive deleted photo recovery program like Asoftech Photo Recovery, you can follow this video to recover deleted photo
http://www.youtube.com/watch?v=sNxApz_PBW8
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 09, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Maxtor external HDD not detected by Vista
try to format it.it might need a quick format for you to use it. if still doesnt work check for the sata,pata cable that connects your motherboard.
Apr 30, 2009 | Maxtor Hard Drive
Unit is on but, will not show on my computer
what could be the solution of acfaulty hard disk?
Mar 16, 2009 | Maxtor Hard Drive
Did a master reboot on my computer
I had this problem and found that by holding down the shift key whilst re-connecting the drive solved it.......not permanently but it has worked on several occassions
Mar 01, 2009 | Maxtor Personal Storage 3100 (M01E100) 100...
250gb Maxtor External HardDisk not responding
How are you connecting it to your pc?  are you supplying external power?
Jan 01, 2009 | Maxtor Hard Drive
Maxtor One-Touch 4 750gb power light flashes and goes out straight away.
Try to remove the drive and connect it directly to another computer.
If still doesn't spin up then most likely the board has failed.
Nov 03, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Maxtor 90845D5 EIDE HDD jumper settings
Connected the 2 pins furthest away from the power connector.
Pin 1
J1 IDE Connector | J2 Power
| .................... || @ * * * || X X X X |
| .......... ......... || @ * * * * || X X X X |
J50 Master/Slave -----+ | | | | | | | +-+12V
J48 Cable Select -------+ | | | | | +---+12V Return
J46 4092 Cyl Limitation---+ | | | +----- +5V Return
J44 Factory Reserved -------+ | +------- +5V
J42 Factory Reserved ---------+
Hope this helps.
Andy
Jun 28, 2008 | Maxtor Hard Drive
Broken portable hard drive - Maxtor (750)
I HAVE A RECOVERY UNIT IN MUMBAI INDIA . YOU CAN GET MY EMAIL ADDRESS FROM THIS SITE .. WE CAN BEGIN FROM THERE AS THERE IS A HARD DISK DAMAGE WHICH HAS TO BE RECTIFIED
Jun 13, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
