Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Your DC connector is probably loose from the system board:
You may have a bad DC connector:
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
You have a bad or loose DC connector on the system board:
You have a bad DC connector, which came loose from the system board:
Problem symptoms:
Here is a tutorial on how to fix a DC connector problem. You may want to have a tech fix it.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
