Question about HP Pavilion dv6000z Notebook
Hp notebook dv6000 how to restore desktop icons
We lost all the desktop icons and toolbar it just shows a blank screen yet all the folders are there and we can get on internet. when we shut down and restart there isa dropdown of the folders, but nothing on desktop what to do??
    Genius:
  • 2,028 Answers
Try running a system restore.
Posted on Jul 29, 2008
Blank screen
This sounds like corrupted Windows and will require a software reload, however you might try this to make things easier in the mean time... (written for XP)
Right click in the taskbar (usually at the bottom of the screen). If 'Lock the Taskbar' is checked, click it to uncheck. Next, click 'toolbars' and 'Desktop'. This should put a new toolbar in your taskbar called Desktop. You should be able to push this all the way to the right. Now when you want to access the desktop Icons, they will be available at the double arrows on the right of the word Desktop. I keep mine this way all the time so I can access stuff on the desktop even when it is covered with open windows.
May 06, 2010 | Tablets & eReaders
Web cam short cut
double click on my computer - it will show the webcam - right click on the webcam icon and select send to desktop - create a short cut.
Jul 23, 2009 | HP Pavilion dv6000z Notebook
I have lost the volume control icon from the desktop toolbar and want to restore it
To display the volume icon in the taskbar notification area, you must select the "Place volume icon in the taskbar" check box in Control Panel Sounds and Audio Devices applet.
May 21, 2009 | Dell Inspiron 1501 Notebook
DELL 800 TRIES TO BOOT
To enable those icons and more, right click on your desktop and choose Properties. Click on the Desktop tab and hit the Customize Desktop button. Next, under the General tab, check off any of the icons you want to appear on your desktop.
Mar 31, 2009 | Dell Latitude D800 Notebook
I deleted the recycle icon by accident i would like to get it back please?
Assuming you didn’t turn off all your desktop icons (right-click your desktop, choose View from the menu, and choose Show Desktop Icons if it doesn’t have a check next to it, which will turn them back on), it’s easy to get back, so stop your sweating and follow these simple steps.
  1. Right-click on your desktop and choose Personalize
  2. Click on the Change Desktop Icons link in the upper left hand corner
  3. In the Desktop Icons Settings window, check the Recycle Bin box and click OK
WORKAROUND in case the above does not work loadTOCNode(1, 'workaround'); If you cannot restore the Recycle Bin by using the resolutions that are listed in this article, work around this issue by creating a shortcut to the Recycle Bin: 1. Click Start, and then click My Computer. 2. On the Tools menu, click Folder Options. 3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box. 4. Click Yes when the warning message appears, and then click OK to close the Folder Options dialog box. 5. Click Folders on the toolbar.
Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons. 6. In the left pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop. 7. On the Tools menu, click Folder Options. 8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.Note This procedure does not re-create the original icon. However, this procedure restores most of the features of the Recycle Bin, including the following: • Delete a file by dragging it to the Recycle Bin icon on your Desktop. • Retrieve a file that you deleted by double-clicking the Recycle Bin icon on your Desktop, right-clicking the file that you want to retrieve, and then clicking Restore. • Empty the Recycle Bin by right-clicking the Recycle Bin icon on your Desktop, and then clicking Empty Recycle Bin. When you use these step to work around the problem, you cannot right-click the Recycle Bin shortcut to access the Recycle Bin Properties. To set properties for the Recycle Bin, follow these steps: 1. Double-click the Recycle Bin shortcut on the Desktop. The Recycle Bin folder opens. 2. In the upper left corner of the Recycle Bin folder, right-click the Recycle Bin icon, and then click Properties.
Aug 20, 2008 | Gateway Computers & Internet
Recycle bin
Mar 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Recycle bin got deleted
Laptop not showing desktop just remains blank when switched on
hi mikkk,
try the following.
1. right click on your desktop (blank screen ). go to arrange icons by--> check show desktop icons. this might fix the issue.
2. or in the task manager. go to file--> new task....Run "explorer.exe" ( type it without the inverted comas). this wud fix the issue.
hope to get rated as helpful.
regards.
bzoy
Jan 03, 2008 | Acer Aspire One PC Notebook
HP Pavilion ze2000
right click on the desktop and choose Arrange Icons By >> Show Desktop icons
Dec 22, 2007 | HP Pavilion ze2000 Notebook
HP Pavilion dv6000z Notebook Logo
156 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
