Question about Canon LaserCLASS 3170 All-In-One Printer
How to forward an incoming fax to another number with a canon laserclass 3170
  • bevqoof Jul 29, 2008
    Setting Up the Fax for Document Transfer
    Follow the procedure below to create a file for switching the fax automatically
    into the transfer mode.
    1. Open the TRANSFER menu.
    Open all three of the One-touch Speed Dialing panels. Then press
    Data Registration.
    Data
    Registration REGISTRATION
    1.DATA REGISTRATION
    Set
    Press Set.
    DATA REGISTRATION
    1.USER SETTINGS
    Press the search buttons until you see the display below.
    DATA REGISTRATION
    6.FILE SETTINGS
    Set
    Press Set.
    FILE SETTINGS
    1.CONFID. MAILBOX
    FILE SETTINGS
    6.TRANSFER
    Set
    Press Set.
    TRANSFER
    1.SETUP FILE
    Chapter 7 Receiving Documents 7-15
    Receiving
    Documents
    2.
    Set
    Press Set. Then press the search buttons to scroll the display so
    you can see each setting.
    SETUP FILE
    1.FILE NAME
    SETUP FILE
    6.PRINT RX DOC.
    3.
    Set
    Press Set then follow the summary in the table below to perform
    the settings.
    4. Stop Press Stop to return to standby.
    Transfer Setup Summary
    The default settings, shown in bold below, remain in effect unless
    you change them.
    1.FILE NAME Enter a file name up to 24 characters long.
    2.SELECT LOCATIONS Select the numbers of the fax machines where you want
    documents transferred.
    TEL = Close the One-touch Speed Dialing panels
    and press a One-touch Speed Dialing button
    or press the Coded Dial button followed by a
    three-digit code for the Coded Speed Dialing
    number to enter the number of the fax
    machine where you want documents transferred.
    The telephone number of the destination
    fax must be registered for One-touch or Coded
    Speed Dialing on your fax.
    3.PASSWORD 0000-9999
    Enter a four-digit number (0000-9999) to protect the transfer
    file settings. Use of a password is recommended. This operation
    password protects the transfer file from unauthorized access
    to your settings. You will also need to enter this password
    when you put the fax in the document transfer mode.
    7-16 Receiving Documents Chapter 7
    Transfer Setup Summary (Cont'd)
    4.SELECT ORIG UNIT Allows you to set the fax to receive and relay documents
    only from originator fax units that you designate.
    OFF All fax transmissions are received and
    transferred.
    ON The fax machine receives and transfers
    transmissions only from fax units that you
    designate by fax telephone number.
    TEL = Press the One-touch Speed Dialing button or
    press the Coded Dial button followed by the
    three-digit code to designate the originator
    fax machines for receive and transfer. The
    telephone number of the originator fax must be
    registered for One-touch or Coded Speed Dialing
    on your fax.
    5.TIME SETUP* Sets the time to move the fax into and out of the transfer
    mode. If you do not set the timer, you can still switch the fax
    into the transfer mode manually.
    1.START TIME Set a time to move the fax automatically into the transfer
    mode.
    EVERY DAY : Sets the fax to move into the transfer mode
    every day. You can set up to 5 starting times
    for every day of the week.
    SELECT DAYS 1.SUN to 7.SAT Sets the fax to move into the transfer mode
    only on selected days of the week.
    : You can set up to 5 starting times for the
    selected days.
    2.END TIME Sets the time for the fax to leave the transfer mode and
    return to the normal mode.
    EVERY DAY : Sets the fax to move out of the transfer mode
    every day. You can set up to 5 end times for
    SELECT DAYS 1.SUN to 7.SAT Sets the fax to move out of the transfer mode
    : on selected days of the week. You can set up
    to 5 end times for the selected days.
    Scholar:
  • 117 Answers
Do you have the device connected to your network? If so, you can go to it's web management interface by entering it's IP address into your web browser's url bar. You will want to look under Add. Func., Fax Forwarding.
Posted on May 06, 2009
How do I get it to accept incoming faxes?
Make sure the phone cord is connected to the PROPER jack on the Canon fax machine. It has 2 of them. One is for the optional handset that you would use to speak into.
Jan 05, 2016 | Canon LaserCLASS Fax 710 Printer
How do I forward incoming faxes from a Canon Laserclass 2050P to another number?
The easiest way to do this is to contact your phone company to divert the calls directly to another phone number.(Call divert)
Oct 23, 2009 | Canon LaserClass 2050 Plain Paper Fax
Trouble transferring to another fax machine
error 330 is bad news the power supply needs repair. First press the data registration button scroll down to file settings and press set scroll down to transfer and press set depending what was programmed you can start new and program in the fax number to where its going and select which days and time when you want it transferred. When you are finished you must push the TRANSFER button underneath the one touch panel for this feature to take effect. It will say transfer on the display.
Mar 26, 2009 | Canon LaserClass 7000 Plain Paper Fax
How do I reset the fax to my co. name and phone #?
Here is the user manual:
http://www.procopyoffice.com/Manuals/LC3170/LASER%20CLASS%203170%20Series%20Users%20Guide.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 19, 2009 | Canon LaserCLASS 3170 All-In-One Printer
Turn off fax ringer - turn on phone ringer Laserclass 2060P
Hi
You can set it for manual mode.
Or set it for fax only but set the incomming ring count to more than 8 times that will give you time to answer a call before it go to fax.
Jan 05, 2009 | Canon LaserClass 2060P Plain Paper Fax
Answer ring
Scroll through the menus to access "NUMBER OF RINGS"
Oct 06, 2008 | Canon LaserClass 7000 Plain Paper Fax
Incoming faxes
Follow LINK and that will help you along
Jun 21, 2008 | Canon LaserClass 2060P Plain Paper Fax
Memory full on canon fax-tr177
Try unplugging the power cord for 10 seconds. Do you have ink / paper?
Jun 06, 2008 | Canon LaserClass 2060P Plain Paper Fax
Setting the fax to 2 short rings
Generally, on most newer faxes, there should be a setting under the options or menu for settings. You are looking for the "distinctive ring mode'.
Oct 11, 2007 | Canon LaserClass 9000L Plain Paper Fax
3,387 people viewed this question
old marine
old marine
