Question about Zenith P42W46X 42 in. Plasma EDTV
No Picture Bought Tv in 2005 and had no problems. Turned on tv Sunday evening and got blue, yello and red lines on screen. I can hear everything and change chanels but NO PICTURE. HEEELLLLPPPP!!!!!
  • 2 more comments
  • franklin2230 Jul 30, 2008
    I have unplugged the TV and I have ensured all cable wires and lines were secure. The TV was working fine for the past couple of years and all of a sudden it stopped working and produced the multi-colored lines. Again sound is present when each channel is changed but NO PICTURE.
    Looking r a solution. Can anyone help?
    Thanks. Sounds like a plan but I want to give others a chance to respond too.
  • franklin2230 Jul 31, 2008
    Thanks VOTIT Your suggestions were clear and concise. Thanks!!!!
    Master:
  • 382 Answers
Theres a blown capacitors on the inverter / vga board replace them and all will be good..That the best solution buddy!!..Try it out!!...Thank you...
Regards!!!!...
Posted on Jul 30, 2008
    President:
  • 2,267 Answers
I would suggest to use the video and audio inputs instead of the RF input and see if the problem persist, if the failure still there even using the AV inputs then your plasma has a hardware failure.
  • Jaime Hernandez Jul 30, 2008
    Reports from other customers say that there could be loose contacts or faulty grounds causing those lines.
    Abrsvcs suggestions could be the first step(s) to take in trying to fix the plasma.
  • 4,234 Answers
The problem you are having is not one that an external cable problem will cause. The video signal is converted to a digital stream inside the set. The symptom that you describe sounds like a problem with the digital stream. I assume that the set is no longer under warranty. If that is true, I would take off the back and reseat all of the cables and connectors. The signal levels inside are extremely low and any dirt or dust can cause odd problems. Try reseating things first and update this. We'll look into more detailed things later.
Dan
  • 282 Answers
Go here
    Sergeant:
  • 260 Answers
Have you checked to make sure your video connection is still plugged in? What type of connections are you using?
You should try replacing the connections before replacing parts on the tv.
What kind of signal (cable, satellite, etc) are you using?
CH
Posted on Jul 29, 2008
  • Ken Jones
    Ken Jones Jul 30, 2008
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. Type can hardly be read, even the TV menus are hard to read. The next day, hoping...
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. TypeHi. Sunday evening the picture on my Sony Bravia suddenly went very red
Aug 03, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Blocks of Colour displaying
 This tv has severe problems in the image processor - you bought a dud. Try getting your money back.
Jun 26, 2010 | Samsung Televison & Video
Pioneer Elite Pro-118 rear projection tv
ya mine did something close to the same. at the moment i covered the blue canon inside the tv now the picture isnt 2 of eveything. the tv comes apart easy from the front good luck mike
May 02, 2010 | Pioneer PRO-200 60" Rear Projection...
Projection TV flickering blue screen, cannot access devices
Did you ever get this problem solved. I am having the exact same problem?
Nov 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Problem with Poloroid LCD 32 in. TV
stiv0's Support Profile at FixYa will give you detailed instructions for repairing your set
Jan 15, 2009 | Polaroid FLM-3732 Television
Zenith P42W46X 42 inch EDTV
common problems with these, usually customers here a loud pop. then the screen goes blank. I would try...
Some of these have a 4 pin test on the control board that you can jump with solder to get test pattern. If you get it to do that then these boards maybe good and would replace the control board. if nothing happens, then
the upper & lower drive also the Ysus and Zsus boards all at the same time.
last could be a defective panel.
hope this helps. p/n are on all the boards.
Jul 22, 2008 | Zenith P42W46X 42 in. Plasma EDTV
Sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Vs-60607 brightness problems
This sounds like it is a problem with the tv. Mitsubishi does have a problem with filter caps in thier regulator circuits. A repair tech will have to fix it.
Mar 06, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Samsung 40 no picture
If it is only 6 months old you probably still have a warranty. This is definitely a hardware issue, and unless you are comfortable taking your new TV apart, I would contact Samsung for repair.
Dec 11, 2007 | Samsung LN-S4051D 40 in. LCD Television
Zenith P42W46X 42 in. Plasma EDTV Logo
23 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
