Question about Sub-Zero 695/O Side by Side Refrigerator
SUBZERO 695 MY ICE MAKER QUIT, WATER HAS SINCE BEGUN DRIPPING FROM ???? SOMEWHERE OUT THE BOTTOM LEFT HINGE. MAN CAME TO FIX IT, REPLACED THE CONDENSER FAN AND SAID I AM GOOD TO GO.... NOT AN HOUR LATER DRIPS AND POOLING HAVE BEGUN OUT THE HINGE. i DO NOT SEE FROM WHERE THE WATER IS COMING?? NEEDLESS TO SAY HE HAS TO COME BACK. HELP
  • rkeesling Aug 15, 2008
    have same leak at lower left hand hinge
  • 71 Answers
Try this... the water valve in your sub. is located in the upper part. ( close to the condenser fan motor. yes the new one.) tell your TECH to test the water dispenser and by pass the ice maker. the leak is on top part . running all the way dow. good luck.............................LEAVE YOUR COMMENT IF IT WAS GOOD FOR YOU.... THANKS
Posted on Apr 02, 2010
Subzero 695 Ice/Water dispenser problem.
maybe ice formed around chute from leaky air seal??? warm area with hair dryer blowing hot air up into chute for 10 minutes. check for water and wipe all off. unplug refg and plug in after 3 minutes to reset electronics
if helpful please rate me. if not please tell me more.
Mar 03, 2012 | Sub-Zero 695/O Side by Side Refrigerator
We installed a new subzero side by side 2 years ago and have had problems with the icemake off and on. Now it doesn't make ice and the appliance center does not seem to be able to fix it. The have...
did they check the water valve?does it fill with water?all it does is the ice maker calls for water,the valve fills it,the water freezes,the cubes dump out and it fills again,most of the time it's either the ice maker or the water valve,if they changed the ice maker and the board all that's left is the valve or a broken wire somewhere in the ice maker harness
Feb 11, 2011 | Refrigerators
My subzero 650 ice maker drips water w/o making ice. Makes a mess with ice build up. I had to turn off water lined to stop the ice maker from dripping. Turning off the ice maker switch did not stop the ice...
Good day,
No, a new water valve should solve that problem. The diaphram in the valve is not completely closing.
Very common problem.
Thank you for using FixYa
Dec 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
My subzero 695 ice maker and water dispenser quit working. Do you have any ideas what I can do to make them start working again?
You might want to check out this forum. Your water controls on both the ice maker AND the door water are out? Could be a power supply issue or perhaps your unit only uses one water flow solenoid. Either way, head to this website and look for a forum for your unit.
http://safemanuals.com/brand-user-guide-instructions-owner-manual/SUB-ZERO
Dec 11, 2009 | Sub-Zero Refrigerators
Model GD5PHAXLB01 Ice Maker
Probably the dual valve (solenoid) is leaking and overflood the ice maker.
Sep 24, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker made too much ice, then none at all...
buy the water valve and the ice maker. replace. water valve locate in the bottom part of the unit. remove kickplate. (left side blue color). ice maker little trick to replaced. (special the 2 screws in the upper part.) call 1800 222 7820. subzero. for your closest store
Sep 19, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Sub zero 532: noise increasing.
We have the same SubZero unit and the water leak is the ice maker line or the pan that catches condensation. If you unscrew the panel at the bottom, you will be able to take the pan out and see if the water is from there. If it is from the ice maker line (which was plastic on ours), you should fix this right away as we didn't and we ended up having a $10,000 flood that ruined our hardwood floors. Also, the increased motor noise happened to us as well, but when we had the motor replaced, it is not much quieter.
Nov 15, 2008 | Sub-Zero 632 / S
Water/Ice Dispenser Does Not Consistently Work
Sammy, I am having the same problem with my 695. I have a call into subzero service and will let you know what I find out.
Thanks for your help as it fixed my problem as well, albeit temporarily.
Alan
Jan 12, 2008 | Sub-Zero 695/O Side by Side Refrigerator
Sub-Zero 695/O Side by Side Refrigerator Logo
255 people viewed this question
Top Sub-Zero Refrigerators Experts
Mike Cairns
Mike Cairns
halftank123
ACME Sub Zero...
ACME Sub Zero...
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
